Posted April 13, 201411 yr Ok, so I'm new to slipstreaming. I wanted to slipstream as many updates as possible, as I really dislike spending hours installing them when I reinstall windows. I am using a software called Windows Hotfix Downloader to retrieve the updates. I have now downloaded everything in the updates list. Now while going through all of it I have IE9 cab and exe. Same for 10 and 11. Do I need to slipstream both the cab and the exe or only one? Do I need to slipstream ie9 and 10 or can I go straight to ie11? I am going to include all the updates from the General, Security and Hotfix section, what should I take from the Additional/Extras section besides IE... Note:I am doing this for both x86 and x64 disks. Thanks in advance, tommis15
April 14, 201411 yr From Additional, integrate these:PlatformPlatform UpdatesIE11 CABsIE11 UpdatesWindowsMediaCenterWinHelpWUClientonly IE11 is enough and needed to be integrated from Extra, generally you don't need any unless you know what they are for
April 14, 201411 yr Use cab OR exe. Pick only the IE you want for final. Don't forget to add the prerequisites and updates for it. I'd add WUClient.
April 14, 201411 yr Author Thank you very much abbodi, I really appreciate it! Can someone explain the Non-Platform/Platform updates?
