Posted May 14, 201410 yr Hello, KB2952664 has been published in early May, but it was again yesterday as an update where the text was (Posted: Today) where can I get the patch manually from?Thank you
May 14, 201410 yr Here:http://catalog.update.microsoft.com/v7/site/Search.aspx?q=2952664 Quote KB2952664 has been published in early May, but it was again yesterday as an updateThe actual file is KB2952664-v2, the file from early may was the first release. Thiersee Edited May 14, 201410 yr by Thiersee
June 23, 201410 yr yes i have 2 cab filesWindows6.1-KB2952664-x86.cab 2.291 kbWindows6.1-KB2952664-v2-x86-express.cab 45kb
June 23, 201410 yr .CAB-files are useless for integration, have a look here, post #2.Here you get the right file. Thiersee
June 23, 201410 yr Cab files are fine for integration (not the express ones,) what do you think is stored in the msu?
June 23, 201410 yr On 6/23/2014 at 5:44 PM, ricktendo said: Cab files are fine for integration (not the express ones,) what do you think is stored in the msu?Of course Rick, it was my fault !My intention was to say "express-files " . Thiersee
