I install the sidebar on 2 computer, after the installation, it's work perfectly but when I install it on the other computer, I get a little problem there, there is an error on the gadget motion when I drag it.
in the first computer , when I move the gadget above another gadget, that gadget move below the dragged gadget to make space for the dragged gadget, but in the second computer, there's no animation ( I mean, there's the gadget just move in a blink of an eye, there's no motion in it ).
And when I insert the windows media gadget, when I click the "<" parts to show the now playing list, the main menu ( the round one ) move outside the screen so it can't be seen,
can someone please tell me what's going on with my second computer?, because it works fine on the first computer ( which is connected to the internet )
and this is the picture of the "error" wmp gadget, I hope someone can help solving this problem so anyone who get the same problem will be solved too
Ya I have that WMP bug also. Sorry to say but its VAIO and I dont think any of them are going to be fixed, since they stopped updating it :(
Now the animation bug... not sure what could be the cause of that
owh, thanks for the reply,
but why it's works fine on my first computer?, and I have tried to install almost every program in my first computer to the second computer, ( both of them have same specs, xp SP2 ) and still, it's not working fine in the second computer, how could I know why the sidebar works fine in my first computer?
I get
regsvr32.exe - Entry Point Not Found
The procedure entry point Wow64EnableWow64FsRedirection could not be located in the dynamic link library vKERNEL32.dll.
error when I drag and drop it, it also happen in my first computer...,
Actually, I'm using sokoolz installer...
and I realize that the "Vista-Sidebar-installer-v1.7.8"( by thoosje ) works on my first computer but don't work on my second computer, it says .....has encountered an error and need to be closed, sorry for the inconvinience... or something like that, is there any link between your sidebar and thoosje?,
Thanks, now the regsvr32 is working,( I have registered the dll ) but the sidebar problem still exist...
I have use your installer but the motion & wmp error still occurr...
and I realize a little bug again, the words "Gadgets" when we point up the "+" sign in the sidebar not appear in my second computer ( this screen shot is taken in my first computer ), and even the thoosje sidebar version 2.0 also not working on my second computer, ... umn, one more thing, sometimes, a few gadget appear to be blank white when the sidebar is loaded ( this happen in both computer )
thank's for the reply btw
The words when you hover over the + are not showing because you have set your PC for Best Performance, just set it for Best Appearance
Remember not all gagdets work... but tell me which one is it that i see blank, what the name of it?
GOD! THANK'S it solve all my problem in the second pc! ( including wmp, gadget and motion error )! thank you very much !!!!
but, why is some gadget appear blank white sometimes (although if we close and reopen it, it will be fix)?
Right click on My Computer, choose properties, go to the advanced tab and hit the performance settings button and choose adjust for best apperance
Off Topic: check the control panel you will see a sidebar properties shortcut ;)
