kanyos Posted May 22, 2014 Posted May 22, 2014 (edited) Source: MSIAfterburnerSetup430.exeReleased: October, 2016PreRequisites: Visual C++ Redistributable 2008 x86About: MSI Afterburner is a handy overclocking utility for graphics cards. Main features include GPU/Shader/Memory clock adjustment, advanced fan speed and GPU voltage control. Removed: - Translation files - RTSSSetup.exe (Rivatuner Statistics Server Application) - Skins, except default skins and MSICyborg skins - replaced vcredist installer with vcredist installer repacked for smaller size Tweaked: disable AutoUpdate inside MSIAfterburner.cfg--> UpdateCheckingPeriod=0 File name: MSIAfterburner430-Setup.exeSize: 10,6MBMD5: E8568A3E8441B123D539C12D581F8E7FDownload: http://www.mediafire.com/file/dsx6tfxr86x06ld/MSIAfterburner430-Setup.exe Edited October 27, 2016 by kanyos Boskorp, Docthal and alfreire 3 Quote
kanyos Posted September 15, 2014 Author Posted September 15, 2014 updated to version 4.0.0 Docthal 1 Quote
kanyos Posted May 28, 2015 Author Posted May 28, 2015 new version with new skin: v4.1.1 :thumbsup_anim: Docthal and alfreire 2 Quote
Docthal Posted December 14, 2015 Posted December 14, 2015 does this include the hotfix/rebuild version? Quote
kanyos Posted December 17, 2015 Author Posted December 17, 2015 does this include the hotfix/rebuild version?no, only old version of vcredist installer Docthal 1 Quote
Reducer Posted January 30, 2016 Posted January 30, 2016 Hi kanyos. I like this repack, but it contains exe 4.2.0.7825. Current official package contains build 7826. There was a hotfix the day after the initial release (I think that was Docthal was asking about). Other changes include: updated dlls, updated cards database pdf and additional skins (though I'm not sure if you purposedly removed them for the repack). Also the included vc_redist is twice as bigger than the one in your repack, but package versions seem to match (?). Not sure if related, but an error window popped up when installing your repack about "something" was already installed and that the installation will not continue. After closing it (no other choice), MSIA finished installing and works ok so far. I think the error came from the vc_redist kicking in and failing to install, but I can't be sure (freshly installed, fully updated 7ux64 with latest vc_redist from ricktendo.) I would like to request an updated repack if possible. Important: please include option to choose the installation folder when run in GUI mode. Quote
kanyos Posted January 31, 2016 Author Posted January 31, 2016 12 hours ago, Reducer said: Hi kanyos. I like this repack, but it contains exe 4.2.0.7825. Current official package contains build 7826. There was a hotfix the day after the initial release (I think that was Docthal was asking about). Other changes include: updated dlls, updated cards database pdf and additional skins (though I'm not sure if you purposedly removed them for the repack). Also the included vc_redist is twice as bigger than the one in your repack, but package versions seem to match (?). Not sure if related, but an error window popped up when installing your repack about "something" was already installed and that the installation will not continue. After closing it (no other choice), MSIA finished installing and works ok so far. I think the error came from the vc_redist kicking in and failing to install, but I can't be sure (freshly installed, fully updated 7ux64 with latest vc_redist from ricktendo.) I would like to request an updated repack if possible. Important: please include option to choose the installation folder when run in GUI mode. updated/ Re-upload Reducer and Docthal 2 Quote
Reducer Posted February 1, 2016 Posted February 1, 2016 (edited) Thank you kanyos, that was really fast! Installed with same error (window is titled "Windows Installer"), but working fine. Nice to find that the old skin is used by default and not that bloody cyborg one. No custom install folder though Edited February 1, 2016 by Reducer Quote
Docthal Posted September 2, 2016 Posted September 2, 2016 KANYOS!!! repack new beta version of msi afterburner pls... "430 beta 14" Quote
kanyos Posted October 27, 2016 Author Posted October 27, 2016 On Friday, September 02, 2016 at 8:54 PM, Docthal said: KANYOS!!! repack new beta version of msi afterburner pls... "430 beta 14" updated 4.3.0 stable Quote
