  • Popular Post
Quote
About: These installer contains .NET Framework 1.1, 2.0, 3.0, 3.5 and 4.0 x86 plus updates integrated. For command-line options run <installer_name>.exe /?
Note: This will only install if you run it on Windows XP, will skip if any other. For 100% silent install use: /ai /gm2
OS: Windows XP SP3 x86
  • Replies 102
  • Views 89k
  • ricktendo
    ricktendo
    Updated 4.0: add KB3057756, KB3064706 (rem KB3048074) Sifnificant superseded reg cleanup for 2.0, 3.0 and 3.5
  • Updated with new 7zip sfx
  • Updated Framework 4.0: 2974335, 2894842-v2, 2972215 Updated Framework 3.0: 2973115 Updated Framework 2.0: 2894843, 2972214 Updated Framework 1.1: 2972207 Edit: Fixed
Muchas gracias rick, dos preguntas, este reemplaza a los addons del net que veniamos descargando ? y asi como ya no hay soporte para xp, tampoco va a haber para estos que son para XP, es decir este es el ultimo de los net con las actualizaciones ?,  gracias.
Thanks Rick.  I'll go ahead and ask since I know there are others that would like it, but is there a chance you could make a similar pack for XP x64 and 2003?  ( I assume the same pack could be installed on both? )  I think that type of pack has always been missing from the various .NET offerings.  Just a thought.
+1 for that as for xp x64, net framework 1.1 not available, I'm trying to make that but stuck in what thing that doesn't needed by windows (just like ricktendo did, he's very good in slimming the pack so only needed component will be installed).
Updated with KB2966782
How is the FTP, is it still giving problems?
I would like to no longer have to upload these mirror files (I have slow internet)
BTW I have no plans on adding language packs, too much work for too few people
This one worked for me this time, but I don't know if one success is a sufficient test. :)  Besides, my experience in the last several months has been that the bigger the download the more likely that there will be a problem, and this one is not too big.
Still disconnecting frequently on my side. Quick for about 16MB and then gone. Happens when using FF normal downloader which doesn't support resume. Can't the owner of the FTP debug this?
MediaFire gave me no problems. I still have the option of using another downloader that supports resume if
you decide to kill the mirror.
Edited by click-click
If I wanted to remove .NET 1.1 support, I could: 1) Delete the 'DNF11' folder and 2) Remove lines 63 and 64 (see below) from install.cmd, correct?
START /WAIT DNF11\netfx.msi TRANSFORMS=NETFX11SP1.MST %VERBOSITY% /norestartSTART /WAIT WaitNET.exe %VERBOSITYSHORT%
Edited by Uncle_Gadget
.NET Framework 2.0 SP2 will not be installed, no matter if run silent installation or attended installation.
It was tested in clean VM's with XP with SP3 only.
  • 4 weeks later...
