  • Replies 102
  • Views 89k
  • ricktendo
    ricktendo
    Updated 4.0: add KB3057756, KB3064706 (rem KB3048074) Sifnificant superseded reg cleanup for 2.0, 3.0 and 3.5
  • Updated with new 7zip sfx
  • Updated Framework 4.0: 2974335, 2894842-v2, 2972215 Updated Framework 3.0: 2973115 Updated Framework 2.0: 2894843, 2972214 Updated Framework 1.1: 2972207 Edit: Fixed
Will you be updating the dotNET4 component of this AIO with 2974335 (hotfix rollup) like you did with the dotNET4 full version?
Updated
link in the header of the theme loads the previous version, the hash checksums do not match...
So maybe someone can tell me if what I did was the issue or not...
I took user_hiddens all in one which hasn't been updated and replaced the exe in the zip file with this one (after renaming it  to match and using makecab on the exe).  Went about my normal slipstream process with nlite and all was pefect.  I still had 4 updates for .net 4 however...
kb2901110
kb2898856
kb2901111
kb2898855
I'm not sure if this pack just didn't have these integrated or it was the way I tried updating it myself.  Any input?
Hello is this command that i found on the internet to speed up the framework installation included in this pack? or if not how i can include it?and is it safe for the pack to have it?
%windir%\microsoft.net\framework\v4.0.30319\ngen.exe update /force /queue
Hello,i want to do a silent install but i want to see the progress of each framework installing,what it`s the switch for this?
Edited by symbios24
