Hi Rick,
I want to thank you for your work with the NET Updates so far. It's a great job. I would be very happy if it continues, because I need the .NET Framework (3.0 and 3.5) for the Intel graphics driver for Windows XP. I'm trying to use XP to support the end of POSReady 2009 (April 2019).        Is it true that the support of .NET 4.0 officially ends in January 2016?
So thank you again, I appreciate your work very much.
Edited by rasie
  • Replies 102
  • Views 89k
  • ricktendo
    ricktendo
    Updated 4.0: add KB3057756, KB3064706 (rem KB3048074) Sifnificant superseded reg cleanup for 2.0, 3.0 and 3.5
  • Updated with new 7zip sfx
  • Updated Framework 4.0: 2974335, 2894842-v2, 2972215 Updated Framework 3.0: 2973115 Updated Framework 2.0: 2894843, 2972214 Updated Framework 1.1: 2972207 Edit: Fixed
  • 4 weeks later...
hI ricktendo..  tried your NET Framework AIO for XP x86 (1-10-2016)
i added it to a xp pro sp3 build and KB951847 showed up in windows update after the installation .Microsoft .NET Framework 3.5 Service Pack 1 and .Net Framework 3.5 Family Update for .Net versions 2.0 though 3.5 x86  (KB951847)  69.2 MB size
compiled a new xp iso including your framework aio and also added c++ runtimes and now there is no framework updates needed..
thanks for your work on NET Framework AIO for XP x86
Edited by dude-uk
In February, Microsoft has two new updates for .NET Framework 2.0 released (KB3122646 and KB3127219). Are these updates relevant for XP?
  • 4 weeks later...
recently used " Framework AIO for XP x86 (1-10-2016) "  in a june 2016 xp iso
works ok so long as  c++ 2005 is installed first then there is still no updates to add when test online updates
Edited by dude-uk
  • 6 months later...
hi.. recently made a updated xp december 2016 with framework added..
needed hotfix that showed up in windows update
November, 2016 Security and Quality Rollup for .NET Framework 3.0, 4 on WES09 and POSReady (KB3189598)
Last Modified: 12/12/2016
http://www.catalog.update.microsoft.com/ScopedViewInline.aspx?updateid=0805a922-81f9-4402-8f12-12c07af784d7
Edited by dude-uk
added download link for kb
  • 8 months later...
thanks.. but when clicked it says...
File has expired and does not exist anymore on this server
edit..
got from mirrorcreator mediafire link
thanks is this a new 04.12.2017 version ?
Edited by dude-uk
got file in the end and edited post
28 minutes ago, dude-uk said:
thanks...
  SHA1: 23ED96EEE306D77B55CB8C9ECE1AED06A2DB379B
SHA256: EAC6E49492AC463EE65F6515EA5A117265CC8BA12B5000C8F29145288785DB63
https://nofile.io/f/eHhtHDWHXF6/dotNetFx_AIO_x86_20171010.zip
http://www.mirrorcreator.com/files/4AWJ2V1J/dotNetFx_AIO_x86_20171010.zip_links
2017/05/09 - New: NDP20SP2-KB4014585, NDP20SP2-KB4020517, NDP30SP2-KB4017101, NDP40-KB4014605, NDP40-KB4020510
2017/08/13 - Added .NET 4 update KB4021915
2017/10/10 - Added KB4040968, KB4040962
