As you can see in attached image the WinToolkitRunOnce.exe is there in system32 and it's working if I run it from there after Windows is installed
Why doesn't start normally when Windows Setup x64 it's finished ? WinToolkitRunOnce.exe don't start !
:albert:
Edited by © KEiGHT
It works for me; Win7 Prof x64 with only WU updates!
Thiersee
Hi Thiersee,
I have no other problem with WinToolkit but with RunOnce, he refuse to start !
It's a shame you can't upload your ISO, however there should be a RunOnce log which you can upload :)
 Hi Liam,
I can make a screenshot because is from VirtualBox (testing only)
Which part of log you are interested to be seen ?
http://www.fileshare.ro/e30545007
here is your .log file :)
WinToolkitRunOnce.exe (config file)
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
  <startup>
    <supportedRuntime version="v4.0" />
    <supportedRuntime version="v2.0.50727"/>
  </startup>
  <runtime>
    <NetFx40_LegacySecurityPolicy enabled="true" />
  </runtime>
</configuration>
Maybe Is there an issue not having installed(integrated in windows setup) NET 4.0 ? As I see your soft require v4.0 to run
Please excuse me if I said something wrong but, can you change it to look for v 3.5 ?
to look like this ?
<configuration>
  <startup>
    <supportedRuntime version="v3.5"/>
  </startup>
  <runtime>
    <NetFx35_LegacySecurityPolicy enabled="true" />
  </runtime>
</configuration>
Edited by © KEiGHT
NOT fixed ! Now , you have my log file, what's the problem ?
I wonder why when I click it from his lair will start and why can't start with windows setup ?
What has to do updates with RunOnce ?
Another question is , how to implement the new fixed build, not to start again from the beginning,  my compilation ?
What should be loaded to fix my compilation quickly with the new release?
Edited by © KEiGHT
I have the same problem as you have....It's going fine until the runonce....and then ...nothing,,.,the desktop displays and there are no programs installed . check on control panel also. the same thing....did the test 3 times...2times with the newest version of the wintoolkit and 1 with an older version.
op system is win 7 x64
I don't know why, but , I intend to believe if I make the x64 build in x86 version of windows 7 , RunOnce will work ! Something makes me to believe this WInToolkit has something in common with current Installed OS !
All I intend to do in current version x64 for x86 will work without issues ! Why RunOnce doesn't work for x64 ? I use the original X17... win7sp1 x64 from Digital...
Edited by © KEiGHT
