Sorin Posted May 24, 2014 Posted May 24, 2014 (edited) Problem: Wintoolkit RunOnce won't start!!! I have win7 x64. Tried 3 times on my computer from usb . Didn't test it from cd. It takes too long. Live! No results!!! I am using the latest build of WinToolkit. Edited May 24, 2014 by Sorin Quote
Legolash2o Posted May 24, 2014 Posted May 24, 2014 Do you have the RunOnce log which can be found in the System32 folder? Quote
Sorin Posted May 24, 2014 Author Posted May 24, 2014 4.3.1.0 (Looking for CommandLineArgs...)CommandLineArg: C:\Windows\System32\W7TRunOnce.exe (Looking for CommandLineArgs...)Found Drive: C:\ (Looking for Installation Files...)Found Drive: D:\ (Looking for Installation Files...)Found Drive: E:\ (Looking for Installation Files...)Found Drive: F:\ (Looking for Installation Files...)Found Drive: G:\ (Looking for Installation Files...)Found Drive: C:\ (Looking for alternatives...)Found Drive: D:\ (Looking for alternatives...)Found Drive: E:\ (Looking for alternatives...)Found Drive: F:\ (Looking for alternatives...)Found Drive: G:\ (Looking for alternatives...)IDrive: (Looking for alternatives...)No IDrive Found: (Aborting: No installation files found...) this is the log. Quote
BiuS Posted May 24, 2014 Posted May 24, 2014 (edited) do you remove the usb once the installation copy all the files and reboot for the first time? Edited May 24, 2014 by BiuS Quote
Sorin Posted May 24, 2014 Author Posted May 24, 2014 no, i didn't. the usb was at all times present in the slot. Quote
Legolash2o Posted May 25, 2014 Posted May 25, 2014 4.3.1.0 That's a very old version of the RunOnce. When did you last run WinToolkit with the image? Quote
Sorin Posted May 25, 2014 Author Posted May 25, 2014 yesterday. i tried with different versions of win toolkit even with the latest i've tried and nothing Quote
BiuS Posted May 25, 2014 Posted May 25, 2014 are you messing with the services or/and removing anything from the iso? Quote
Sorin Posted May 25, 2014 Author Posted May 25, 2014 at the services tab i checked the tweaked button...and that's all. i didn't removed a thing. Quote
BiuS Posted May 25, 2014 Posted May 25, 2014 i had a similiar problem when i used the safe preset. try no preset. and give it a go Quote
