Hi Liam,
First sorry, my english is very bad. I hope can explain the problem.
1. Below updates Wintoolkit say "This update has NOT been integrated." but integrated. After install Windows update not show
WUClient-SelfUpdate-ActiveX-x86 and x64
WUClient-SelfUpdate-Aux-TopLevel-x86 and x64
WUClient-SelfUpdate-Core-TopLevel-x86 and x64
 982018
2670838
2830477
2592687
2. If Assessment and Deployment Kit 8.1 installed. Nothing integrated. I cannot exactly remember version, but previously WTK version not have this error.
Uninstall the 8.1 kit and use system DISM integrated normally.
If not uninstall 8.1 kit. I try change options. Change dism path 8.1 dism to system dism
This does not seem to be DISM. "Turkish dism info"  Would you like to add it anyway?
After click OK nothing changed and use 8.1 deployment kit dism.
Only solution is uninstall 8.1 deployment kit.
dism.7z
3. IE11 Hotfix not moved to Internet Explorer section
File names are;
ie11-windows6.1-kb2909210-x86
ie11-windows6.1-kb2929437-x86
ie11-windows6.1-kb2953522-x86
4. Options not saved
I use ramdrive and letter is "Z"
Temp Folder always reset to "C:\Windows\Temp\WinToolkit"
Browse and select temp folder to Z drive. Path is automatically changed to "Z:\WinToolkit_Temp\WinToolkit_Temp"
External Apps and DISM Priority not saved. Always reset to "Normal"
5. Clicking main windows options button, windows position changed. Options windows always change positions.
6. Add Runonce not selected. But Wintoolkit create install.ini file under sources directory.
Edited by Legolash2o
:-) The Updates do you integraded are x64!!!!!
But Your wuclient are x86 ;-)
Please Check your Bit System (x86 or x64) and The Updates You will integraded
both have this problem. Post edited. Thank you :)
At first take the newest WinToolkit V 1.4.46.1.
Microsoft has got a new Update Agent Version.
http://support.microsoft.com/kb/2887535/en-us
Windows 7 x64 SP1 - http://download.windowsupdate.com/windowsupdate/redist/standalone/7.6.7600.320/WindowsUpdateAgent-7.6-x64.exe
Windows 7 x86 SP1 - http://download.windowsupdate.com/windowsupdate/redist/standalone/7.6.7600.320/WindowsUpdateAgent-7.6-x86.exe
1. Save it
2. Extract the Exe
3. Extract WUA-Win7SP1
4. Take the new WUClient (WUClient-SelfUpdate-ActiveX, WUClient-SelfUpdate-Aux-TopLevel, WUClient-SelfUpdate-Core-TopLevel)
To the KB's, please redownload it!
