Hi,
Dism for Windows 7 offers no function to remove components like in Windows 8 or at least I didn't find it.
Example for Dism in Windows 8
DISM.exe /Online /Disable-Feature /Featurename:Solitaire /Remove
However in Windows 7 you can remove single components via Control Panel -> Programs and Features -> Turn Windows Features on or off.
This starts OptionalFeatures.exe, but I couldn't find any arguments for this exe. With WinToolkit you can for example only remove the whole game group, but not single games.
Is there a way to remove components via a command?
Unfortunately, Windows 7 does not have that option with DISM to remove/disable components from the DVD.  That feature was added to the Windows 8 DISM (but also is not able to remove/disable items under Win7).
An alternative way around that is to use an autoattend.xml to install *only* what you want from your install disk. That is about the only way to "not" have some items installed under Windows 7.
SIDE NOTE:  It appears that the "optionalfeatures.exe" does not have any command line options.  (One *might* be able to use an autoit or vbs script to automate an option removal, however this would only be able to be performed on a live working system.)
  • 4 months later...
for example in bat file...
Dism /online /Disable-Feature /FeatureName:TabletPCOC /norestart
Dism /online /Disable-Feature /FeatureName:FaxServicesClientPackage /norestart
Dism /online /Disable-Feature /FeatureName:Printing-XPSServices-Features /norestart
Dism /online /Disable-Feature /FeatureName:Internet-Explorer-Optional-x86 /norestart
Dism /online /Disable-Feature /FeatureName:Xps-Foundation-Xps-Viewer /norestart
Dism /online /Disable-Feature /FeatureName:TIFFIFilter /norestart
Dism /online /Disable-Feature /FeatureName:WindowsGadgetPlatform /norestart
Dism /online /Disable-Feature /FeatureName:MediaPlayback /norestart
Dism /online /Disable-Feature /FeatureName:WindowsMediaPlayer /norestart
Dism /online /Disable-Feature /FeatureName:MediaCenter /norestart
Dism /online /Disable-Feature /FeatureName:OpticalMediaDisc /norestart
Dism /online /Disable-Feature /FeatureName:Printing-Foundation-Features /norestart
Dism /online /Disable-Feature /FeatureName:Printing-Foundation-InternetPrinting-Client /norestart
Dism /online /Disable-Feature /FeatureName:MSRDC-Infrastructure /norestart
if you want disable features in install.wim, create a new folder (here C:\new), mount install.wim in "new" folder and use dos command:
Dism /Image:C:\new /Disable-Feature /FeatureName:TabletPCOC
Dism /Image:C:\new /Disable-Feature /FeatureName:FaxServicesClientPackage
Dism /Image:C:\new /Disable-Feature /FeatureName:Printing-XPSServices-Features
Dism /Image:C:\new /Disable-Feature /FeatureName:Internet-Explorer-Optional-x86
Dism /Image:C:\new /Disable-Feature /FeatureName:Xps-Foundation-Xps-Viewer
Dism /Image:C:\new /Disable-Feature /FeatureName:TIFFIFilter
Dism /Image:C:\new /Disable-Feature /FeatureName:WindowsGadgetPlatform
Dism /Image:C:\new /Disable-Feature /FeatureName:MediaPlayback
Dism /Image:C:\new /Disable-Feature /FeatureName:WindowsMediaPlayer
Dism /Image:C:\new /Disable-Feature /FeatureName:MediaCenter
Dism /Image:C:\new /Disable-Feature /FeatureName:OpticalMediaDisc
Dism /Image:C:\new /Disable-Feature /FeatureName:Printing-Foundation-Features
Dism /Image:C:\new /Disable-Feature /FeatureName:Printing-Foundation-InternetPrinting-Client
Dism /Image:C:\new /Disable-Feature /FeatureName:MSRDC-Infrastructure
here is for x86 windows 7 features.
unmount with save
important: for works, you need original winsxs backup folder. Erase it after if you want.
Edited by kalimergo
