Imagex is completely Obsolete ?????? now does all the Dism.exe http://technet.microsoft.com/en-us/library/hh825258.aspx  imagex I think in the future will be removed
however http://msdn.microsoft.com/en-us/library/windows/desktop/dd834960.aspx i do not know if it's true but once heard (by non-professional users) about that DISM.exe was faster the GimageX http://www.autoitscript.com/site/autoit-tools/gimagex/ or other, and the GimageX is written in C++ by people who know how to write a code ehhh, I mean like if there are doubts on the efficiency of the interpretation of the Imaging API (WIMGAPI), as said are just words in the air (unverified) without any kind of foundation
Ciao.
Edited by OnePiece
  On 6/10/2014 at 2:42 PM, Legolash2o said:
I could use DISM but if I remember correctly I struggled to get the progress % of the mount/unmount, etc..
I already told\indicated\suggest you two years ago ehhh ;)
  On 9/2/2012 at 3:38 PM, OnePiece said:
Sorry Legolash2o only now i have seen this Post, if you use DISM.exe or Imagex.exe need to use the ReadConsoleOutputCharacter to read the "[-----%XX----]"
you write in C# right, here http://www.pinvoke.n...tCharacter.html
Sorry for my English
Ciao.
I tested it years ago (as always in\with\using AutoIt), and it's all OK, but hmmmmm for 3 years now I can not find free time to Upgrade\Update\RewriteAll WinNT6.x True Integrator ehhhh, I mean I do not know how it behaves with the latest release of Dism, but I believe is how they should be, as always must be all 100% OK
Ciao.
Edited by OnePiece
