wela Posted June 10, 2014 Posted June 10, 2014 I used 1.4.4.2 to build install source with win7 pro.AiO went fine, build iso too.Installing in VM no Problems, till reaching the runonce installation. There is a strangebehavior finishing the installation.Last file is 947821-v33.After finishing these installation a little message window appear with a status bar and therunonce installer restart the Installation.I canceld and the system boot into desktop.Wu no Probelms, all Files seems correct installed.Attached session.ini.Test_14_42.zip Quote
wela Posted June 10, 2014 Author Posted June 10, 2014 (edited) Did you want it to restart?No. Why should i want it? It is not necessary. Update:I just finished a installation based on v14389. All fine. Edited June 10, 2014 by wela Quote
wela Posted July 10, 2014 Author Posted July 10, 2014 (edited) HiUsed 14.44.3. Same issue as above described. After finishing all silent installer (the last is kb947821-v33) message windows shown shortly like "scanning for files", "scanning folders", "removing duplikates" and after that the Runonce installer start again installing all silent installer files. Again, with 14.38.9 no Problem. Is there a Runonce.log? Found it - attached. Also attached Runonce log from 1.4.38.9 installation. Wintoolkit_runonce_log.rarWTK_runonce_log_v14389.rar Edited July 10, 2014 by wela Quote
wela Posted July 14, 2014 Author Posted July 14, 2014 Hi Lego Did you find a reason why wtk-runonce in 1.4..44.3 did not work correct on my System?! Quote
Legolash2o Posted July 14, 2014 Posted July 14, 2014 I did some changes in v1.4.44.4 which hopefully will help. I'm releasing it now. Quote
wela Posted July 14, 2014 Author Posted July 14, 2014 Hi Lego Thanks for fixing. I am sorry but the Runonce installer give me a message I don´t understand. Cause i do nothing (See Pic_1).After clicking "ja" (yes) the second message appears (see Pic_2). It says "That Runonce did not function in right order. Close the Program."After clicking "Close Program" the system starts to desktop. All Files installed. Sys is running well. Runonce.log/config attached. WTK_Runonce_Error_Pic_Log.rar Quote
Cartman586 Posted July 15, 2014 Posted July 15, 2014 (edited) 1.4.45.1 :-( WinToolkit installed the files,but after the Installation he bring a error! :-( Pic1: without Keyboard inputPic2: when I press yes from Pic1 Windows 7 x64 + x86, Windows SBS2011, Windows Server 2008R2, Windows 8.1U1, Windows Server 2012R2 U1 testet!!! Edited July 15, 2014 by Cartman586 Quote
Legolash2o Posted July 15, 2014 Posted July 15, 2014 Strange considering you have v1.4.44.4 RunOnce when it should be v1.4.45.1 :/ Test 2 released Quote
Cartman586 Posted July 15, 2014 Posted July 15, 2014 Hi, i have downloadet 1.4.45.1 and have integrated. See Screens! Is here a wrong Version from runonce in the Wintoolkit 1.4.45.1? Quote
Legolash2o Posted July 15, 2014 Posted July 15, 2014 I've confirmed that 1.4.44.x was in that test build, uploaded 45.2 with the new RunOnce. Quote
wela Posted July 15, 2014 Author Posted July 15, 2014 (edited) 1.4.45.2 :-( I´m sorry. I confirm, WTK_Runonce did not work correct. Edited July 15, 2014 by wela Quote
Thiersee Posted July 15, 2014 Posted July 15, 2014 Hi Lego, last version I tested was 1.4.44.Test3, all was OK.Today I tested 1.4.44.4 (NOT B!) and I got the same error like in post #9 (wela) and #11, #12 & #17 (Cartman586).I tried now (just finished) 1.4.45.2: it seems the error has gone.To the error it appears after the last silent-installer has finished; the only difference I noticed is: in 1.4.44.T3 (working) the RunOnce can be in background or not,since 1.4.44.4 is only and always on top; is it OK? Would be possible to get it again in background? For all test: allways same ISO with same patches, same silent installers, same preset. Thiersee Quote
John_95 Posted July 15, 2014 Posted July 15, 2014 maybe your need to redo it from scratch. I had the same problem. What it did was re-download anew windows iso and re did all of the integrating with an new preset. after that it worked Quote
Legolash2o Posted July 16, 2014 Posted July 16, 2014 Yeah I will set it in the background. At the moment i'm just trying to re-produce the bug as it's working fine for me when I run it normally. If anyone wants to upload the image where the problem is happening, that would make it easier for me Quote
Legolash2o Posted July 16, 2014 Posted July 16, 2014 I think I've managed to fix it, but your ISO should confirm it. Thanks Cartman! Quote
Thiersee Posted July 16, 2014 Posted July 16, 2014 I must correct my post #19:1.4.45.Test2 does not work reliably; just finished 2 more installations, 1 VM and 1 real HW, in the VM no error, with the real Hardware error. Win7 Prof x64. Thiersee Quote
