So I spent the last 10 hours editing an iso and learning to use Wintoolkit.
I've edited windows before but normally after a clean iso install. Tried using WTK to edit the iso before install, save time etc.
Is there a log file I can post?
I added alot of updates via Alphawaves' updater (all the regular ones 469, and a few didn't take)
I added some addons: Waterfox, winrar, ccleaner/ccenhancer, Coretemp and coretemp gadget (all work fine)
I did component removal (games, music, pictures etc. features and things I never use) - Games still show up and work ... :(
(I removed them via Component removal and disabled them via Tweaks.. but they still work lol)
I did four silent installs (reapers adobe flash/activex and netframework aio  and  4.5.2, VBC++ aio) all found on these forums.
I think all the silent installs failed? or sort of =/
An error popped up upon first boot to desktop something about unkown error (and flash loads youtube, but not in Uninstall Programs either; asks for update in browser)
Net framework verifier shows 2, 3, and 3.5  but not 4-4.5.2 and windows asked me like 6x with a DOS prompt to insert a disk into drive A (no such drive lol)
waterfox keeps telling me its not default even though i tell it to be. MS wants to download another 223 mb<>27 updates. heh.
I attached my preset, and an .ini file created when I began to compile via AIO. No Log files were in the log folder
AIO creation .ini
*AIO|v1.4.42.1|Sunday 15 June 2014  1:02:12 AM
#Addons
D:\Downloads\Reapers.CCleaner.4.13.4693.shell.ext.only.x64.Windows7.or.8.AddOn.WA
D:\Downloads\Reapers.Core.Temp.1.0.RC6.Windows7.or.8.AddOn.WA
D:\Downloads\Reapers.WinRar.5.01.x64.Windows7.or.8.AddOn.WA
D:\Downloads\Reapers.Waterfox.18.0.1.x64.Windows7.or.8.AddOn.WA
#Components
Australia Local Pack
Canada Local Pack
Clips In The Library
DVD Maker
Great Britain Local Pack
Inbox Games
Internet Games
Media Features
Music and Video Examples (Ringtones)
New Zealand Local Pack
Premium Inbox Games
Sticky Notes
Tablet PC Components
TV Tuner Drivers
United States Local Pack
Windows Media Center
Windows Media Format Runtime
Windows Media Player
Windows Media Player DVD Registration
Windows Media Player Network Sharing Service
#Gadgets
D:\Downloads\CoreTempGadget\CoreTempGadget2.7.gadget
#Services
Adaptive Brightness::Disabled
Bluetooth Support::Disabled
Branch Cache::Disabled
Certificate Propagation::Disabled
Distributed Link Tracking Client::Disabled
Encrypting File System (EFS)::Disabled
Fax::Disabled
FTP::Disabled
Function Discovery Provider Host::Disabled
Function Discovery Resource Publication::Disabled
Link-Layer Topology Discovery Mapper::Disabled
LPD Service::Disabled
Media Center Extender::Disabled
Net.Msmq Listener Adapter::Disabled
Net.Pipe Listener Adapter::Disabled
Net.Tcp Listener Adapter::Disabled
Net.Tcp Port Sharing::Disabled
Netlogon::Disabled
Network Access Protection Agent::Disabled
Offline Files::Disabled
Parental Controls::Disabled
PnP-X IP Bus Enumerator::Disabled
Portable Device Enumerator::Disabled
Problem Reports and Solutions Control Panel Support::Disabled
Remote Desktop Configuration::Disabled
Remote Desktop Services::Disabled
Remote Desktop Services UserMode Port Redirector::Disabled
Remote Procedure Call (RPC) Locator::Disabled
Routing and Remote Access::Disabled
Smart Card::Disabled
Smart Card Removal Policy::Disabled
SNMP Trap::Disabled
Tablet PC Input::Disabled
TPM Base Services::Disabled
WebClient::Disabled
Windows Biometric::Disabled
Windows CardSpace::Disabled
Windows Color System::Disabled
Windows Connect Now - Config Registrar::Disabled
Windows Error Reporting::Disabled
Windows Media Center Receiver::Disabled
Windows Media Center Scheduler::Disabled
Windows Media Player Network Sharing::Disabled
Windows Process Activation::Disabled
Windows Remote Management (WS-Management)::Disabled
WinHTTP Web Proxy Auto-Discovery::Disabled
WWAN AutoConfig::Disabled
#Silent Installs
Reapers.Adobe.Flash.Player.ActiveX.13.0.0.214::;NO;10.56 MB;D:\Downloads\Reapers.Adobe.Flash.Player.ActiveX.13.0.0.214.exe;Always Installed
Reapers.Adobe.Flash.Player.Plugin.13.0.0.214::;NO;8.19 MB;D:\Downloads\Reapers.Adobe.Flash.Player.Plugin.13.0.0.214.exe;Always Installed
VBCRedist_AIO_x86_x64::/y;NO;21.87 MB;D:\Downloads\VBCRedist_AIO_x86_x64.exe;Always Installed
dotNetFx452_Full_LDR_x86_x64_Slim::/y;NO;46.48 MB;D:\Downloads\dotNetFx452_Full_LDR_x86_x64_Slim.exe;Always Installed
KB2809215::N/A (Not Needed);NO;398.20 KB;D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2809215-x64.msu;Always Installed
#Theme Packs
C:\Users\Edgarhighmen\Desktop\ffxiv_n5.themepack
#Tweaks
500ms Delay Aero Peek
Show 'Computer' on Desktop
Allow 3rd Party Themes
Disable Drive Autorun
Force Aero
Mouse Hover Time::20
Remove 'HomeGroup' from Explorer
Remove 'Libraries' from Explorer
Show Hidden Files & Folders
Disable Auto Reboot after installing updates
Disable Windows Media Player AutoUpdates
Open NFO files with notepad
Word Wrap in Notepad
Clear History on Exit
Disable Accelerator
Disable Default Browser Check
Disable First Run Customize
Disable Internet Explorer to Check for Updates
Disable Password Caching in Internet Explorer
Disable Signature checking for EXEs
Disable Warning on Close (Tabs)
Faster Browsing in IE
IE Homepage::https://www.google.com/
Launch Internet Explorer in Separate Process
Remove 'Favorites' Menu from IE
Remove Links Bar
Set Google as Search Provider
Turn Off RSS feed discovery
Unlimited Simultaneous Downloads
Computer::Link
Documents::Hide
Downloads::Hide
Favorites::Hide
Games::Hide
Homegroup::Hide
Music::Hide
Network::Hide
Pictures::Hide
Recorded TV::Hide
Run::Show
Videos::Hide
Open submenus when mouse hovers over item::Enable
Disable User Account Control
Disable Bandwidth Limit
Disable CPU Parking (AMD)
Disable Hibernation
Disable Superfetch
Disable Windows Error Reporting
Don’t allow Windows to turn off devices
Enable MAC File Sharing
#Updates
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB917607-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB982018-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2461631-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2487292-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2492386-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2493989-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2506014-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2506928-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2608658-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2640148-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2660075-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2670838-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2685811-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2685813-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2699779-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2709981-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2719857-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2732059-v5-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2732500-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2750841-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2760730-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2773072-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2775511-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2779272-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2786081-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2791765-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2799926-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2800095-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2808679-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2818604-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2820331-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2834140-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2843630-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2847077-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2852386-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2856676-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2868116-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2882822-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2885698-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2888049-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2891804-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2893519-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2905454-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2908783-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2913152-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2918077-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2919469-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2929733-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2929755-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2935092-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\Windows6.1-KB2952664-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\WUClient-SelfUpdate-ActiveX-x64.cab
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\WUClient-SelfUpdate-Aux-x64.cab
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\General\WUClient-SelfUpdate-Core-x64.cab
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2479943-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2511455-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2525835-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2560656-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2564958-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2570947-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2579686-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2604115-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2619339-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2620704-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2621440-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2631813-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2643719-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2654428-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2690533-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2698365-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2705219-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2727528-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2729452-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2736422-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2742599-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2756921-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2770660-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2803821-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2807986-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2813430-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2835361-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2835364-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2840631-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2844286-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2847311-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2847927-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2861191-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2861698-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2861855-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2862330-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2862335-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2862973-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2863240-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2864058-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2864202-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2868038-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2871997-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2876331-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2887069-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2892074-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2893294-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2894844-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2898851-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2900986-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2911501-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2912390-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2923392-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2926765-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2929961-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2931356-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2939576-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2957503-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Security\Windows6.1-KB2957509-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB911589-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB949843-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB967351-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB972959-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB976042-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB980380-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB982559-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB999994-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2276594-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2401553-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2417168-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2427341-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2443643-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2446607-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2456741-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2457458-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2462182-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2465285-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2466048-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2466493-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2467167-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2472264-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2475491-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2477932-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2480641-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2480994-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2486635-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2486644-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2493006-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2495313-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2496898-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2502333-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2502789-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2503784-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2506628-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2508120-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2509318-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2514642-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2516889-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2519400-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2519735-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2519946-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2520487-v4-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2521416-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2524840-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2526629-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2529781-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2529825-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2535158-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2537203-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2538047-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2545561-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2546868-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2549067-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2549079-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2550648-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2554231-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2554859-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2554876-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2555189-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2555392-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2555948-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2561821-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2569389-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2575866-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2575928-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2577968-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2578214-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2581608-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2582679-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2584475-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2584577-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2591271-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2591857-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2600100-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2603203-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2612905-v4-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2614892-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2615327-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2615701-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2616386-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2616879-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2618301-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2618535-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2618640-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2619260-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2619836-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2624868-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2625737-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2627489-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2635500-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2636056-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2636963-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2638018-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2639043-v5-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2639077-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2640472-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2641634-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2642357-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2644491-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2645594-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2645610-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2647878-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2648039-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2649904-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2652029-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2653312-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2659158-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2660677-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2661796-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2662288-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2662585-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2663607-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2664203-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2668395-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2674705-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2675806-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2680097-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2680243-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2683484-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2683913-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2684982-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2685889-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2685893-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2686369-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2686795-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2687862-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2690750-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2691156-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2693187-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2695321-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2695426-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2697479-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2697738-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2698888-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2698957-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2699780-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2700336-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2701373-v4-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2704299-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2704377-v6-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2706168-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2707135-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2707157-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2707589-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2708857-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2710594-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2710832-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2712331-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2717045-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2718646-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2718841-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2719248-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2719305-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2721259-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2722729-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2724133-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2724137-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2725604-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2727107-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2732072-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2732840-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2733955-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2735209-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2735433-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2736469-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2738898-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2740180-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2740232-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2741416-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2742185-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2742483-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2746119-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2750692-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2752259-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2752407-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2755105-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2755625-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2756263-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2756651-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2763342-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2765067-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2765546-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2767652-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2767671-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2768486-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2768494-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2768523-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2769121-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2769791-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2777201-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2780124-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2780130-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2780410-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2781571-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2782486-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2783429-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2784148-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2787046-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2794422-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2796313-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2796725-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2796764-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2797749-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2797789-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2797822-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2798040-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2799464-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2800170-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2800422-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2801423-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2801662-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2809097-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2809808-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2810177-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2812463-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2815716-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2815853-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2819485-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2820467-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2823655-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2824491-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2824560-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2826164-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2826910-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2829262-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2829537-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2831013-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2831206-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2831347-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2832829-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2833914-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2834548-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2834911-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2834976-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2835595-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2837108-v4-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2843376-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2846340-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2847295-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2847346-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2847625-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2847635-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2848224-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2848576-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2851323-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2855028-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2856310-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2858684-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2860842-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2862067-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2865346-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2866086-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2866772-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2869606-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2870165-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2870256-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2870437-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2870467-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2871085-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2872543-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2876213-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2877115-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2878035-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2878068-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2878378-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2878391-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2878563-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2882780-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2884172-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2884284-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2884927-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2885209-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2885210-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2886127-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2886366-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2891144-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2892678-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2893634-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2894906-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2895044-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2896146-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2896256-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2896881-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2900635-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2903025-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2905216-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2905407-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2906850-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2907020-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2907094-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2911204-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2912821-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2912883-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2913607-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2913763-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2914677-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2914748-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2915094-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2916627-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2917033-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2918833-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2918893-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2920486-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2921916-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2922059-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2922514-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2922852-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2923238-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2923388-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2923766-v5-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2923884-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2924171-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2925489-v3-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2926456-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2926993-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2927111-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2927193-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2927767-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2927901-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2928492-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2928496-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2928800-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2931129-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2932119-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2932722-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2936341-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2936943-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2937668-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2939399-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2939652-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2950358-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2951611-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2952507-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2953722-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2956344-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2956671-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2956701-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2956703-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2957560-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2957775-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2958122-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2958399-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2961132-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2962059-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2964048-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2964073-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2964511-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2964643-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2965351-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2965768-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2966148-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2966779-v2-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2966897-x64.msu
D:\Downloads\WinToolkit_1.4.42\Updates\Windows7-x64\Hotfix\Windows6.1-KB2966921-x64.msu
#Wallpapers
C:\Users\Edgarhighmen\AppData\Local\Microsoft\Windows\Themes\FFXIV_ARR\DesktopBackground\ffxiv_01.jpg
C:\Users\Edgarhighmen\AppData\Local\Microsoft\Windows\Themes\FFXIV_ARR\DesktopBackground\ffxiv_02.jpg
C:\Users\Edgarhighmen\AppData\Local\Microsoft\Windows\Themes\FFXIV_ARR\DesktopBackground\ffxiv_03.jpg
C:\Users\Edgarhighmen\AppData\Local\Microsoft\Windows\Themes\FFXIV_ARR\DesktopBackground\ffxiv_04.jpg
C:\Users\Edgarhighmen\AppData\Local\Microsoft\Windows\Themes\FFXIV_ARR\DesktopBackground\ffxiv_05.jpg
C:\Users\Edgarhighmen\AppData\Local\Microsoft\Windows\Themes\FFXIV_ARR\DesktopBackground\ffxiv_06.jpg
C:\Users\Edgarhighmen\AppData\Local\Microsoft\Windows\Themes\FFXIV_ARR\DesktopBackground\ffxiv_wp07.jpg
#Options
Compatibility Check
Create Backups
Enable CMD
Failed Updates to Silent Installers
Integrate 'HDC' Drivers (boot.wim)
Integrate 'SCSIADAPTER' Drivers (boot.wim)
Integrate 'SYSTEM' Drivers (boot.wim)
Move Known Problem Updates to Silent Installers
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Remove Invalid Drivers
Retry Updates
Show Duplicates
preset.ini
*AIO|v1.4.42.1|Saturday 14 June 2014  10:48:17 PM
#Addons
#Components
Canada Local Pack
DVD Maker
Inbox Games
Internet Games
Media Features
Premium Inbox Games
Sticky Notes
TV Tuner Drivers
#Gadgets
#Services
Fax::Disabled
FTP::Disabled
Netlogon::Disabled
SNMP Trap::Disabled
WebClient::Disabled
#Silent Installs
#Tweaks
Force Aero
Change The Download Directory::D:\Downloads
Disable Accelerator
Remove Links Bar
Computer::Link
Documents::Hide
Downloads::Hide
Favorites::Hide
Games::Hide
Homegroup::Hide
Music::Hide
Network::Hide
Pictures::Hide
Recorded TV::Hide
Run::Show
Videos::Hide
Disable Hibernation
Disable Superfetch
#vLite
Delete 'WinSXS\\Backup' Folder
#Wallpapers
#Options
Compatibility Check
Create Backups
Enable CMD
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Retry Updates
Show Duplicates
2014-06-15_01-01-31_Windows7Custom.ini
Preset.ini
Edited by Frank Barbieri
  • 4 weeks later...
I have the same problem. Seems like everything installed but NONE of the silent installs.
Didn't notice any error messages while Windows installed.
Did you figure it out Frank?
Similar Content
