Posted June 16, 201410 yr I'm a big fan of everything that gets achieved here, however I was running into an issue that I think will start popping up in a few places. There seems to now be 4 updates for Windows 8.1 that have LDR Updates (update-bf.mum) available; Normally LDR updates can be integrated using DISM by pointing to the extracted update-bf.mum. However I ran into some trouble attempting to integrate these updates using Add-WindowsPackage PowerShell Module. Considering PowerShell should provide most of the DISM functions i was curious if LDR Updates are possible with Add-WindowsPackage. Otherwise I yet to find a powershell equivalent of a couple of other functions, but that could be a discussion for another thread. I am attempting to integrate the update-bf.mum from the following KB'sKB2898847KB2898850KB2931358KB2934520I am attempting using the following powershell scripts.######## ------- INTEGRATE UPDATES - GDR -------- ########Get-Content $INI\$EDITION-UPDATES-GDR.INI | ForEach-Object {Invoke-Expression "Write-Host -ForegroundColor Yellow 'Integrating GDR Update: $_'; Add-WindowsPackage -Path $MOUNT -LogLevel Errors -LogPath $LOGS\DISM-UPDATE-GDR.LOG -ScratchDirectory $SCRATCH -NoRestart -Verbose -PackagePath $UPDATES\$_"}######## ------- INTEGRATE UPDATES - LDR - STILL BROKE -------- ########Get-Content $INI\$EDITION-UPDATES-LDR.INI | ForEach-Object {Invoke-Expression "Write-Host -ForegroundColor Yellow 'Integrating LDR Update: $_'; Add-WindowsPackage -Path $MOUNT -LogLevel Errors -LogPath $LOGS\DISM-UPDATE-LDR.LOG -ScratchDirectory $SCRATCH -NoRestart -Verbose -PackagePath $UPDATES\$_\UPDATE-BF.MUM"}I get the following error:Integrating LDR Update: KB2898847VERBOSE: Dism PowerShell Cmdlets Version 6.3.0.0VERBOSE: Target Image Version 6.3.9600.17031WARNING: Failed to add package Y:\ADK\UPDATES\WINDOWS-8.1.1-AMD64\KB2898847\UPDATE-BF.MUMWARNING: Add-WindowsPackage failed. Error code = 0x80070057Add-WindowsPackage : The parameter is incorrect.At line:2 char:5+ Add-WindowsPackage -Path C:\ADK\MOUNT -LogLevel Errors -LogPath Y:\ADK\LOGS\ ...+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : NotSpecified: ( [Add-WindowsPackage], PSArgumentException + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddWindowsPackageCommandLooking at the log entries for these four updates, it appears that it is rejecting anything that is not a .cab or .msu file:[2764] ImageUnmarshallHandle: Reconstituting wim at Y:\ADK\SOURCES\WINDOWS-8.1.1-AMD64.WIM.[2764] ImageUnmarshallHandle: Reconstituting wim at Y:\ADK\SOURCES\WINDOWS-8.1.1-AMD64.WIM.2014-06-16 13:46:31, Error DISM API: PID=2764 TID=2352 Package path needs to be .cab or .msu file - DismAddPackageInternal(hr:0x80070057)[2764] ImageUnmarshallHandle: Reconstituting wim at Y:\ADK\SOURCES\WINDOWS-8.1.1-AMD64.WIM.[2764] ImageUnmarshallHandle: Reconstituting wim at Y:\ADK\SOURCES\WINDOWS-8.1.1-AMD64.WIM.2014-06-16 13:46:40, Error DISM API: PID=2764 TID=2352 Package path needs to be .cab or .msu file - DismAddPackageInternal(hr:0x80070057)[2764] ImageUnmarshallHandle: Reconstituting wim at Y:\ADK\SOURCES\WINDOWS-8.1.1-AMD64.WIM.[2764] ImageUnmarshallHandle: Reconstituting wim at Y:\ADK\SOURCES\WINDOWS-8.1.1-AMD64.WIM.2014-06-16 13:46:49, Error DISM API: PID=2764 TID=2352 Package path needs to be .cab or .msu file - DismAddPackageInternal(hr:0x80070057)[2764] ImageUnmarshallHandle: Reconstituting wim at Y:\ADK\SOURCES\WINDOWS-8.1.1-AMD64.WIM.[2764] ImageUnmarshallHandle: Reconstituting wim at Y:\ADK\SOURCES\WINDOWS-8.1.1-AMD64.WIM.2014-06-16 13:46:57, Error DISM API: PID=2764 TID=2352 Package path needs to be .cab or .msu file - DismAddPackageInternal(hr:0x80070057)Any idea if its possible to integrate LDR updates with Add-WindowsPackage? Edited June 16, 201410 yr by splinterededge
June 16, 201410 yr Author This command line still works of course:######## ------- INTEGRATE UPDATES - LDR -------- ########Get-Content $INI\$EDITION-UPDATES-LDR.INI | ForEach-Object {Invoke-Expression "Write-Host -ForegroundColor Yellow 'Integrating LDR Update: $_'; DISM.EXE /$LANGUAGE /SCRATCHDIR:$SCRATCH /LOGLEVEL:1 /LOGPATH:$LOGS\DISM-UPDATE-LDR.LOG /IMAGE:$MOUNT /NORESTART /ADD-PACKAGE /PACKAGEPATH:$UPDATES\$_\UPDATE-BF.MUM"}Thanks for listening so far, let me know if there is a method to complete this with Add-WindowsPackage
June 16, 201410 yr Author I have substituted the DISM command-line in my script in the meantime, Im using a very simple IF statement that checks for update-bf.mum. When update-bf.mum is detected DISM is used and when its not detected it is installed from Add-WindowsPackage like a normal GDR package.Current LDR / GDR detection and installation######## ------- INTEGRATE UPDATES - LDR/GDR -------- ########Get-Content $INI\$EDITION-UPDATES.INI | ForEach-Object {IF (Test-Path $UPDATES\$_\UPDATE-BF.MUM) { Write-Host -ForegroundColor Yellow "Integrating LDR Update: $_"; DISM.EXE /$LANGUAGE /SCRATCHDIR:$SCRATCH /LOGLEVEL:1 /LOGPATH:$LOGS\DISM-UPDATE-LDR.LOG /IMAGE:$MOUNT /NORESTART /ADD-PACKAGE /PACKAGEPATH:$UPDATES\$_\UPDATE-BF.MUM } ELSE { Write-Host -ForegroundColor Yellow "Integrating GDR Update: $_"; Add-WindowsPackage -Path $MOUNT -LogLevel Errors -LogPath $LOGS\DISM-UPDATE-GDR.LOG -ScratchDirectory $SCRATCH -NoRestart -Verbose -PackagePath $UPDATES\$_ }}I'm still looking to confirm if a 'native' Add-WindowsPackage method exists for LDR updates. Thanks and cheers!
