ntvsys Posted June 25, 2014 Posted June 25, 2014 Hi guys, Is there any possibility how to detect if an update has .net 4.x dependencies? I have trouble installing a win7pro + updates (more than 400+). errorlog says .net error cause not installed. i know in sp1 is a 3.5 but some updates seem to need 4.x.how to detect with one? Install aborted with "Windows ould not configure one or more system components..." then restart loops going to start. Please tell me what information do you guys need to help out. cheers -krutt Quote
John_95 Posted June 25, 2014 Posted June 25, 2014 (edited) ya, KB2819745 needs netframework 4.5 and KB2506143 needs needs netframework 4.0. you should try to use this addon http://www.wincert.net/forum/topic/11127-microsoft-net-framework-452-for-windows-7 then add those updates into the silent installers it contains net framework 4.5.2. you only need to install this for both of the updates to work. Edited June 26, 2014 by John Bruce Nicholson Quote
© KEiGHT Posted June 26, 2014 Posted June 26, 2014 (edited) with Remove Components (Win Toolkit) remove Windows6.1-KB2819745-x64-MultiPkg which are 4 components under list Unknown !Install only Net 4.5.2 / then apply this hotfix ith silent installer or directly offline ! Edited June 26, 2014 by © KEiGHT Quote
