Thiersee Posted July 4, 2014 Posted July 4, 2014 (edited) Hi Lego, the actual version 1.4.43.Build1 creates some TEMP-folders during integration: of course WinToolkit_Mount & WinToolkit_Temp,but some like WinToolkit_Temp_MountTemp_92981689 too: 1 folder during integrating and a total of three during/terminating ISO-Maker!The extra folder are NOT deleted at the end of the job, closing WTK! It does NOT happen with WTK 1.4.42.Build1, no folder created and no folder left. Regards, Thiersee Edited July 8, 2014 by Thiersee Quote
Legolash2o Posted July 4, 2014 Posted July 4, 2014 Can you please attach your settings.txt file. Thanks Quote
Thiersee Posted July 5, 2014 Author Posted July 5, 2014 Here is it: fAddons=E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\ReapersfDrivers=E:\DriverWin7_F2A85XM\AMD\Support\14-4-win7-win8-win8.1-64-dd-ccc-whql\Packages\Drivers\Display\WB6A_INFfSilents=E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\ThierseefUpdates=E:\ServicePacks-Install\Win_7\WindowsUpdateDownloader\Windows 7 Update Post SP1 x86 DE-IT\IE 11sAddRunOnce=TruesAICommands=TruesAVScan=TruesAIOSave=TruesUpdFilter=TruesAIOTIME=10m:07ssPreventSleep=TruesCheckForUpdates=TruesDLogging=TruesFreeRAM=TruesLastDir=E:\Win7_Prof_x64_DE_SP1_X17-59885sLastWIM=E:\Win7_Prof_x64_DE_SP1_X17-59885\sources\install.wimsPLastWIM=E:\Win7_Prof_x64_DE_SP1_X17-59885\sources\install.wim|E:\Win7_Prof_x86_DE_SP1_X17-59886\sources\install.wim|E:\Win7_Prof_x64_IT_SP1_X17-59215\sources\install.wim|E:\Win7_Prof_x64_DE_SP1_X17-59885_Test\sources\install.wim|E:\Win7_Prof_x86_DE_SP1_X17-59886 - Kopie\sources\install.wim|smCheck=FalsesAIOPM=TruesMountTemp=C:\WinToolkit_MountsQuickMerge=TruesFormSize=|frmUpdCatalog:896*431|frmAIODiskCreator:760*464|frmEXEtoMSP:750*400|frmUnattendedCreator:700*706|frmAWUpdCatalog:896*984|frmWIMManager:1123*350|frmAllInOne:1549*925smVerify=FalsesSolDownload=E:\ServicePacks-Install\Win_7\Alphawave_Downloader\sTransparency=100sTransparencyAll=FalsesWinToolkitDISM=HighsWinToolkitExt=NormalsWinToolkitPRI=NormalsWinToolkitTemp=C:\WinToolkit_TempsUploadLogs=TruesLastISO_Folder=E:\Win7_Prof_x64_DE_SP1_X17-59885sLastISO_ISO=E:\ISO's\WinToolkit\W7-P_DE_x64_WUD_A88X_vl_1443B1.isosMountLog=TruesShowWelcome=FalsesRegistryLog=TruesDismLoc=C:\Windows\System32\Dism.exeI did NOT change anything! Quote
Thiersee Posted July 5, 2014 Author Posted July 5, 2014 Same issue with 1.4.44.Test1 The first three open during opening/closing AIO-Integrator, the fourth on opening ISO-Maker. Quote
Thiersee Posted July 5, 2014 Author Posted July 5, 2014 (edited) Try deleting your settings file Done, but the result does not change :sad01_anim:. And I discovered another small, may be only cosmetic, bug:1.4.43.Build1 and 1.4.44.Test1 does not show the key for exclusive ISOs anymore (1.4.42.Build1 does it), but I think the key has been detected, because I can see the exclusive ISOs, therefore I said "cosmetic" . Thiersee Edit: because I can see the exclusive ISOs, Of course I mean I can download ad-free . Edited July 6, 2014 by Thiersee Quote
Thiersee Posted July 8, 2014 Author Posted July 8, 2014 *bump* With 1.4.44.2 the same... Thiersee Quote
Sm0k3r Posted July 8, 2014 Posted July 8, 2014 Having the same problem, temp folders remining even after deleting the settings file. Quote
Legolash2o Posted July 8, 2014 Posted July 8, 2014 A new test version has been uploaded which now deletes the temp folder. You do need to manually delete the current ones though. Note: The temp folders which are created when mounting an image will be deleted AFTER it has been UNMOUNTED. All others will be deleted immediately. Quote
Thiersee Posted July 8, 2014 Author Posted July 8, 2014 Hi Lego, issue has gone with version 1.4.44.3. For the second issue from my post #6 I open another thread. Thiersee Quote
