Translation
I'm testing translation and I was wondering if someone could translate the following file into their language?
UPDATE
Test H released with everyone's translations
  • ro-RO (romanian)
  • it-IT (Italian)
  • pt-BR (Brazilian)
  • en-US (English)
That should be enough for my testing so no need to translate anymore files. Feel free to check them out and let me know of any issues, mis-alignments, etc..
Thank you everyone!
LangFile.zip
  • Replies 75
  • Views 30.4k
  • You can find the test version in the signature of the developer Legolash2o under the Latest builds link.
  • Yes, version 2.0.0.12 : it's a prototype, a "work in progress". Lego is working on this new version, but there is no idea yet, when it will be ready to be released. The translation-files we are talkin
  • Updated Turkish translation.tr-TR.zip
Hi Lego,
My question is important because of our German umlauts:
Is notepad.exe (ANSI) sufficient for editting the TXT file?
BTW: win-lite.de has been revived!
Regards, Nemo
When I write batches (*.bat, *.cmd) I can't use notepad.exe (ANSI !). I use pspad.exe with OEM characters.
Which editor do you use?
Here is Romanian resource.txt
Opened and edited in Notepad.
I think here you messed up a little. I corrected in the translation.
WinToolkitv2.g.en-US.resources:frmmain.baml,btnMSUtoCAB:System.Windows.Controls.Ribbon.RibbonButton.Label,None,True,True,,MSU to CAB Converter
WinToolkitv2.g.en-US.resources:frmmain.baml,btnMSUtoCAB:System.Windows.Controls.Ribbon.RibbonButton.ToolTipDescription,None,True,True,,"Converts *.EXE version of language packs into *.cab so that they can be integrated.
*Can result in quicker integration time."
WinToolkitv2.g.en-US.resources:frmmain.baml,btnMSUtoCAB:System.Windows.Controls.Ribbon.RibbonButton.ToolTipTitle,None,True,True,,Update MSU to EXE
WinToolkitv2.resources.dll_ro-RO.txt
Edited by ianymaty
Oh, the diacritics don't show correctly. I use a US keyboard and I think the keyboard was set to Romanian (traditional). Should I set it to Romanian (standard)? Also there is a Romanian (programmers).
Which one I should use?
post-23920-0-35541900-1404670545_thumb.p
In this new text were deleted all the accents, as a way to show the entire text.
But the version ' E ' would be better for our language, because it contains all the correct spelling.
Here my translation in Italian.
Lego,
I translated the TXT-file (downloaded today morning, my be 11:00).
It's OK or should I translate again, using the CSV-file (If I understand correct UTF-8-Coded, not ANSI).
Thiersee
If i'm honest I'd rather you did the notes on the english version so I can tell what it is you're referring too :)
Thiersee, you've added stuff in column H which look like notes? If i'm honest I'd rather you did the notes on the english version so I can tell what it is you're referring too :)
Because you've added your notes, it wont let me use the file. Attempting to fix though :)
Yes, I've put some notes in my translation, but I asked you to have a look at them (here post #5) ;).
But if it's better for you I can put the comment in the english version, no problem!
I'll do tomorrow.
BTW, if I open the file in Excel almost all the text-lines are written in column A; some lines containing special characters  (', apostroph) are written in column A, B and sometimes C.
Thiersee
Edited by Thiersee
