eturk Posted July 13, 2014 Share Posted July 13, 2014 All the updates seem to be integrating OK, as Windows Update finds very few updates. BUT, all but one silent install is being skipped. Not even put into WinToolkit_Apps folder. I've seen this question asked several times in other threads but no one is answering, thus a thread clearly markets with the issue. help? ----------------from the presets file: #Silent InstallsnVidia::-n -s;YES;436.79 MB;D:\Dell1520\Drivers\nVidia\setup.exe;Always InstalledSynaptics Touchpad::/Q;YES;775.47 KB;D:\Dell1520\Drivers\Synaptics\dpinst.exe;Always InstalledIntelPROSetWireless::/quiet /norestart;NO;69.21 MB;D:\Dell1520\Drivers\IntelWiFi\IntelPROSetWireless.msi;Always InstalledAnti-virus Microsoft Security Essentials::/s /runwgacheck;NO;10.72 MB;D:\Dell1520\Drivers\MSSecurityEssentials\mseinstall.exe;Always InstalledWindows Experience Updater::formal;NO;3.21 MB;D:\Dell1520\Drivers\WinSAT.exe;Always Installed (only winsat.exe makes it to WinToolkit_Apps folder) Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted July 13, 2014 Share Posted July 13, 2014 Strange, I didn't know there was an issue of not even being copied so I'll have to check that :/ Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted July 14, 2014 Share Posted July 14, 2014 Where abouts is your DVD located? (full path) The only thing I can think of that may affect this is if your DVD path + new path of silent installer is larger than 260 characters or whatever that limit is. Quote Link to comment Share on other sites More sharing options...
eturk Posted July 18, 2014 Author Share Posted July 18, 2014 thanks for checking in on this! Ah, a funny goof caused the files to not be copied on just the one build i looked at. It IS copying the files to the DVD build. Is there some additional setting or something I need to do in order for the included additional apps to actually be installed? Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted July 18, 2014 Share Posted July 18, 2014 Should do everything automatically. If you want to add more, just run AIO Integrator again. If, however you need to update an installer. Just replace and overwrite the one already copied. Just make sure the DVD/USB stays in until you see the desktop! I am curious as to what the 'goof' was Quote Link to comment Share on other sites More sharing options...
