Posted July 13, 201410 yr Hi I've just tried the latest Wintoolkit build 1.4.43.1 and two updates don't integrate properly: KB2962409 and KB2955164. They show up in Windows Update. What is curious is although the *.MSU's are 49.6 MB and respectively 97.4 MB, after running Windows Update they show up as being only couple of Kbytes large (~200 KB). Thanks kukubau
July 13, 201410 yr Hi, prerequisite for both KBs is KB2919355 installed! If you have this prerequisite only integrated, it means they are not installed yet, they are only in the status "Install pending".Try to put this two KBs under "Silent Installers". Thiersee Edited July 14, 201410 yr by Thiersee
July 13, 201410 yr Author Needles to say, I've put in wintoolkit KB2919355 and all the other included updates before KB2962409 and KB2955164.
July 14, 201410 yr Needles to say, I've put in wintoolkit KB2919355 and all the other included updates before KB2962409 and KB2955164.To put them before KB2919355 is NOT enough! as I wrote: If you have this prerequisite only integrated, it means they are not installed yet, they are only in the status "Install pending".You must put the two updates under "Silent Installers SFX"! http://support.microsoft.com/kb/2962409/en-us PrerequisitesTo apply this update, you must first install the update 2919355 on Windows 8.1 or Windows Server 2012 R2. For more information, click the following article number to view the article in the Microsoft Knowledge Base:2919355(http://support.microsoft.com/kb/2919355/ ) Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 Update April, 2014 http://support.microsoft.com/kb/2955164/en-us PrerequisitesTo apply this update, you must first install the update 2919355 on Windows 8.1 or Windows Server 2012 R2. For more information, click the following article number to view the article in the Microsoft Knowledge Base:2919355(http://support.microsoft.com/kb/2919355/ ) Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 Update April, 2014 Thiersee
July 14, 201410 yr It works ;-) When Windows search with Update he dosn't found ;-) Edited July 14, 201410 yr by Cartman586
July 14, 201410 yr They can be integrated normally after 2919355 but 2919355 must be integrated first in a separate dism session"Install pending" has no affect or prevent the integration nevertheless, it's recommended to use latest released Update ISO that have 2919355 already integrated
July 15, 201410 yr Author That really wasn't needless to say, it actually was quite needed to know. ) hahaha
July 16, 201410 yr Hi I've just tried the latest Wintoolkit build 1.4.43.1 and two updates don't integrate properly: KB2962409 and KB2955164. They show up in Windows Update. What is curious is although the *.MSU's are 49.6 MB and respectively 97.4 MB, after running Windows Update they show up as being only couple of Kbytes large (~200 KB). Thanks kukubauWas this integrating into Windows 8.1 RTM or Windows 8.1 Update 1?
July 16, 201410 yr Author Hi I've just tried the latest Wintoolkit build 1.4.43.1 and two updates don't integrate properly: KB2962409 and KB2955164. They show up in Windows Update. What is curious is although the *.MSU's are 49.6 MB and respectively 97.4 MB, after running Windows Update they show up as being only couple of Kbytes large (~200 KB). Thanks kukubauWas this integrating into Windows 8.1 RTM or Windows 8.1 Update 1? I used Windows 8.1 Enterprise + Update 1 iso - en_windows_8.1_enterprise_with_update_x64_dvd_4065178.iso I've built another iso with wintoolkit (latest build) today and I've added those two updates under the silent installers. The installation hanged in Virtual Box with the RunOnce window opened. It wouldn't finish installing the updates no matter how long I waited for it. Edited July 16, 201410 yr by kukubau
July 16, 201410 yr en_windows_8.1_enterprise_with_update_x64_dvd_4065178.iso And this is one of the other reasons why we don't support warez. You are in major violation of Forum rule #1. You are getting only one warning WE DON'T SUPPORT OR CONDONE WAREZ HERE....... Any other violations and you'll be banned. This is not open for debate either.
July 16, 201410 yr @Kelsenellenelvian: How do you know that this iso is warez? It is the exact same name as the legitimate iso one can download from Technet with the appropriate Technet subscription. Clark.
July 16, 201410 yr Then its on him to prove he has valid access.All google searches for that name are torrent and warez release links.
November 16, 201410 yr I don't know how to integrate kb2955164 I used Windows 8.1 Pro with updates wintoolkit 1.5.3.3i try to integrate only kb2955164, with normal update, prerequisite or sillent, and i don't work please help
