Ever want to remove some of those little programs you never use that ship with Windows XP? Sure, they're not taking up much space, and hard drives are cheap these days. But it's the principle of the thing, right? And some of these programs don't show up on the Windows XP Add/Remove programs menu.
Well, it appears that the only thing keeping you from uninstalling WordPad, Pinball, or other programs is one word in the sysoc.inf file. You can find sysoc.inf by navigating to \Windows\INF\sysoc.inf. If you open the file in Notepad, you should see a list of programs, most of which will be followed by the word "hide."
All you have to do is delete the word "hide," and save the file. Now when you go to Add/Remove programs, the unhidden programs will be there. Note that not every program can be removed just because you've unhidden it. For example you can't uninstall terminal services.
Sysoc.inf doesn't seem to exist in Windows Vista.
Source: DowloadSquad
