Posted July 27, 201410 yr Hi I integrates the update on my win 8.1.x64 but then iso image exceeds 5GB. What should I do to keep my ISO images fit on a 4.7 GB DVD,does not need updating just re-copying the old files in the system? I can not update Windows8.1-KB2959146-x64.msuPS: If you need a translation into Bosnian/Croatian/Serbian for wintoolkit language I can help Edited July 27, 201410 yr by jigsaw5063
July 27, 201410 yr You could try this dism /Image:<path_to_mount> /Cleanup-Image /StartComponentCleanup /ResetBase
August 22, 201410 yr Result: C:\Windows\system32>dism.exe /Image:C:\Mount /Cleanup-Image /StartComponentCleanup /ResetBaseDeployment Image Servicing and Management toolVersion: 6.3.9600.17031Image Version: 6.3.9600.17031Error: 0x800f0806The operation could not be completed due to pending operations.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logC:\Windows\system32> How to fix? Any tips??
