Posted August 7, 201410 yr WinTooklit version 1.4.46.1 Sometimes won't integrating - Renesas Electronics Corporation USB 3.0 v.2.1.28.1 hub + host drivers into Boot.WIM, but sometimes it does! Why? nusb3co.dllnusb3hub.catnusb3hub.infnusb3hub.sysnusb3xhc.catnusb3xhc.infnusb3xhc.sys
August 7, 201410 yr ....Sometimes won't integrating - Renesas Electronics Corporation USB 3.0 v.2.1.28.1 hub + host drivers into Boot.WIM, but sometimes it does!......This version is old, you can get the last one 2.1.39.0.here http://www.station-drivers.com/index.php/downloads/Drivers/Renesas-Nec/USB-3.0/Renesas-Nec-uPD720200-720200a-USB3-Controller-Drivers-Version-2.1.39.0-WHQL/ or herehttp://www.computerbase.de/downloads/treiber/usb-3.0-host-controller-treiber/ I had such a problem in the past with the "normal" install.wim and the same version as you; the solution was to install the drivers in a running system, the extract them with, for example, Drive Magician Liteand then to integrate the extracted drivers. Regards, Thiersee
