Posted August 12, 201410 yr Hey lego? Why in the heck does discarding images still kick off the rebuilding wim option? If I am discarding a image then the wim doesn't need rebuilt does it?
August 12, 201410 yr Author There is but it makes no sense for the discard button to even kick of rebuilding at all.
August 12, 201410 yr Maybe someone has worked on 4 images previously and then on the last one decided to descard it and rebuild i anyway. OR Someone discards an image and wants to rebuild it, but when it doesn't (because of this thread). They will report it as a bug. Technically it's not a bug since you left the rebuild image option checked and it's doing just that
August 12, 201410 yr The best alternative I can come up with is to remove the checkbox and add a 'Save and Rebuild' option. Save and RebuildSaveDiscardKeep
August 14, 201410 yr Here you go... Sample.png on version 1 or 2? just wanna know since I'm on my (android) tab, couldn't download for a spin test...
August 14, 201410 yr I can release now if you want. Just got to open my birthday cards first as I'm getting old
August 14, 201410 yr I can release now if you want. Just got to open my birthday cards first as I'm getting old Happy Birthday...
August 14, 201410 yr I can release now if you want. Just got to open my birthday cards first as I'm getting old Happy birthday! :beerchug:
