On the first test to convert a file, skiped Step 2 and hit Convert, the D:\OutputDirectory was created and file was converted. I deleted that folder and now it throws a quick error (can't read it as it's really quick flash) and nothing happens. Why it runed the first time to create that "default hinted" directory than it can't repeat it? If I select a folder in Step 2 the file is converted.
Can't add Folder or Folder + subfolder in LP Converter and  EXE to MSP Converter. MSU to CAB accepts them.
Delete update from list don't work in any of the converters.
Any converter selected the Delete updates baloon shows "Remove MSU files from the conversion queue."
Posted (edited)
You mean the error from the first line? I can't realy remember, Forget about it. Seems that now its fixed with the prompt.
Delete updates seems to work too.
Edited by ianymaty
