Posted August 17, 201410 yr using v1 of the unattended creator if i enter a mak key i get an error and i'm unable to install windows. the workaround is that i delete the key from the xml in the winpe setup part and leave it in the specialize part. I'm wondering if adding a check box that you can check for mak keys to skip adding the key to the winpe part in v2. here is a link that shows the issue in greater detail. http://blogs.technet.com/b/askcore/archive/2009/10/05/invalid-product-key-error-specifying-mak-key-in-unattend-xml.aspx Thanks edit: opps saw the rules too late. if you want close it and i'll reopen. Edited August 17, 201410 yr by techbound
