I think I shall keep it. In your translations, feel free to Italian version of 'Output Folder'. Another thing I have noticed is that your translations are bigger than they need to be. For example:
seleziona la cartelle di destinazione : select the destination folder
Could be:
Cartella di destinazione : Destination Folder
The tooltips are there to add a more detailed explanation :P
OK, keep it so.
seleziona la cartella di destinazione : select the destination folder
Could be:
May be...
in which line/key did you noticed?
There are two similar lines/keys
    <system:String x:Key="Global-00000025">Cartella di destinazione</system:String> and
    <system:String x:Key="Global-00000045">Seleziona la cartella di destinazione</system:String>
I send you the last version.
Edit:
If I translate those two keys with "Cartella di destinazione" then you have a duplicate, don't you?
The two lines are different in english too and Italian need sometimes a longer expression.
it-IT.xaml
Edited by Thiersee
