Hi everyone,
i just found that very nice program and trying it out for the first time. I want to integrate some programs into my Windows-Installation without using an Install Switch. What would happen if I integrate some programs with the "Silent Install" option without using an Install Switch. It would be perfect if it starts the manual-installations of the programs one after another at the end of the windows-installation. Would it work like that or is there another way?
Sorry for my bad english.
Thanks in advance.
Yes, it would work, if you use the "normal" installer of your program and not a "Silent-Installer" (unattended).
BTW, what you mean with "installer switch" is "silent switch"
Regards, Thiersee
