Sorin Posted August 24, 2014 Posted August 24, 2014 (edited) I'm sick and tired of this ... Wintoolkit run once doesn't RUN ... what the f*ck am i doing wrong ? I integrated the drivers...i integrated the installers with their respective switches ... NOTHING was removed from component removal , no updates were integrated, used blacks viper safe services, checked some tweaks ... can u please explain to me why the RunOnce doesn't starts running ?!?!?!?!?!?!?!?!? AND FOR SOME REASONS , THE USB DRIVE DOESN'T GET DETECTED !!! After the desktop appears and it displays the icon , when i enter on the Computer icon to see the drive, the USB drive doesn't show up ... i used version 1.4.46.1 Log.... Version: 1.4.45.58/24/2014 6:32:26 PM Description: -----------------STARTING-------------- 8/24/2014 6:32:26 PM Description: IsSystem: FalseIsAdministrator: TrueUser: Sorin-PC\Sorin 8/24/2014 6:32:26 PM Description: Creating Shutdown Handle. 8/24/2014 6:32:26 PM Description: Loading... 8/24/2014 6:32:27 PM Description: Detecting Drives 8/24/2014 6:32:27 PM Description: Detecting Paths 8/24/2014 6:32:27 PM Description: Detecting Sources 8/24/2014 6:32:27 PM Description: Entry Found: 00000|ymsgr_instValue: |%DVD%:\WinToolkit_Apps\ymsgr_inst\ymsgr_inst.exe*/s 8/24/2014 6:32:27 PM Description: Drive Found: C:\ Fixed 8/24/2014 6:32:27 PM Description: Drive Found: D:\ Fixed 8/24/2014 6:32:27 PM Description: Drive Found: E:\ Fixed 8/24/2014 6:32:27 PM Description: Drive Found: F:\ Fixed 8/24/2014 6:32:27 PM Description: File Found P1: %DVD%:\WinToolkit_Apps\ymsgr_inst\ymsgr_inst.exeP2: /s 8/24/2014 6:32:27 PM Description: ERROR REG P1: %DVD%:\WinToolkit_Apps\ymsgr_inst\ymsgr_inst.exeP2: /s 8/24/2014 6:32:27 PM Description: Entry Found: 00001|firefoxValue: |%DVD%:\WinToolkit_Apps\firefox\firefox.exe*-ms -ira 8/24/2014 6:32:27 PM Description: File Found P1: %DVD%:\WinToolkit_Apps\firefox\firefox.exeP2: -ms -ira 8/24/2014 6:32:27 PM Description: ERROR REG P1: %DVD%:\WinToolkit_Apps\firefox\firefox.exeP2: -ms -ira 8/24/2014 6:32:27 PM Description: Entry Found: 00002|ChromeStandaloneSetupValue: |%DVD%:\WinToolkit_Apps\ChromeStandaloneSetup\ChromeStandaloneSetup.exe*/silent /install 8/24/2014 6:32:27 PM Description: File Found P1: %DVD%:\WinToolkit_Apps\ChromeStandaloneSetup\ChromeStandaloneSetup.exeP2: /silent /install 8/24/2014 6:32:27 PM Description: ERROR REG P1: %DVD%:\WinToolkit_Apps\ChromeStandaloneSetup\ChromeStandaloneSetup.exeP2: /silent /install 8/24/2014 6:32:27 PM Description: Entry Found: 00003|LoaderValue: |%DVD%:\WinToolkit_Apps\Loader\Loader.exe*/VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP- /TASKS="desktopicon" 8/24/2014 6:32:27 PM Description: Entry Found: 00004|yusetup7Value: |%DVD%:\WinToolkit_Apps\yusetup7\yusetup7.exe*/VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP- /TASKS="desktopicon" 8/24/2014 6:32:27 PM Description: File Found P1: %DVD%:\WinToolkit_Apps\yusetup7\yusetup7.exeP2: /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP- /TASKS="desktopicon" 8/24/2014 6:32:27 PM Description: ERROR REG P1: %DVD%:\WinToolkit_Apps\yusetup7\yusetup7.exeP2: /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP- /TASKS="desktopicon" 8/24/2014 6:32:27 PM Description: Detecting Drivers 8/24/2014 6:32:27 PM Description: x64: True 8/24/2014 6:32:27 PM Description: Removing Duplicates. 8/24/2014 6:32:27 PM Description: No Installations. 8/24/2014 6:32:27 PM Description: No installation Paths 8/24/2014 6:32:38 PM Description: Starting 8/24/2014 6:32:38 PM Description: Manual: 0 | Driver: 0 | Auto: 0 8/24/2014 6:32:38 PM Description: InstallPaths: 0 8/24/2014 6:32:38 PM Description: Deleting dpinst.exe 8/24/2014 6:32:38 PM Description: Removing Shutdown Handle. Edited August 24, 2014 by Sorin Quote
Legolash2o Posted August 29, 2014 Posted August 29, 2014 Is see quite a few errors in that log. I will check them tomorrow. I also need to add more logging as it doesn't say what the error is. That was silly of me! Quote
Legolash2o Posted August 30, 2014 Posted August 30, 2014 What drive is 'WinToolkit_Apps' on? It seems like it is not picking up the install folder. Also, is it a CD, DVD, USB, etc...? Quote
Sorin Posted August 30, 2014 Author Posted August 30, 2014 i use a usb for the install....and the drive folder is located in E:\ Quote
Legolash2o Posted August 30, 2014 Posted August 30, 2014 So it's definitely E:\WinToolkit_Apps, etc... I believe the problem is that it's not finding that path. However, I hoping it's a threading issue which I've just fixed. EDIT: I've uploaded a test version. Quote
Sorin Posted August 30, 2014 Author Posted August 30, 2014 (edited) thx Lego. I'm gonna do the test tomorrow. P.S : The path to wintoolkit_apps is : E:\Driverpacks.net x64\X17-59465\WinToolkit_Apps Edited August 30, 2014 by Sorin Quote
Legolash2o Posted August 30, 2014 Posted August 30, 2014 That's prob why it is not working. It needs to be E:\WinToolkit_Apps or E:\Sources\WinToolkit_Apps unless an additional location is specified within the install.ini file. Quote
Sorin Posted August 31, 2014 Author Posted August 31, 2014 so.. i have to re-add the installers from a different location , right ? Quote
Legolash2o Posted August 31, 2014 Posted August 31, 2014 No. Just move the WinToolkit_Apps to the root of the installation source. Do you boot from USB or do you run setup.exe. I'm slightly confused at the folder structure of your USB stick Quote
Sorin Posted August 31, 2014 Author Posted August 31, 2014 Always boot from usb. I've just sent you a PM . Please read it. Quote
Legolash2o Posted September 7, 2014 Posted September 7, 2014 I've made quite a big change in the latest test build. Please give it a try Quote
