Posted August 28, 201410 yr Quote FunctionalityMount *.mdx, *.mds/*.mdf, *.iso, *.b5t, *.b6t, *.bwt, *.ccd, *.cdi, *.bin/*.cue, *.ape/*.cue, *.flac/*.cue, *.nrg, *.isz disc images to a virtual driveCreate .iso, *.mds/*.mdf and *.mdx images of CD, DVD, Blu-ray discsCompress your imagesProtect images with passwordManage your Image Collection Media devices virtualizationCreate up to 4 virtual devices (DT and SCSI in all) to mount several images simultaneouslyCustomize virtual drives: change a drive letter, DVD region, etc Simple user interface with basic system integrationGet quick access to all functionalities via program icon in the System TrayUse File Associations to mount images right from Windows ExplorerUse powerful Command Line Interface for automation purposesPerform basic actions via handy DAEMON Tools Gadget on Windows DesktopDAEMON Tools Lite v4.49.1.356 Info: NO adware, also the follwing options have been DISABLED: Use tray agent, Autostart, Automount, Check for updates, Enable Media Info panel, Send anonymous usage statistics. MD5: ff6102f6dd899ea3842926aa0f9eea65 Size: 9.55 MB Download: http://adf.ly/1713566/dtliterepak Website: http://www.daemon-tools.cc SCSI Pass Through Direct a.k.a SPTD v1.87 (Windows XP/Vista/7/8/8.1 x86/x64) Info: Optional, for advanced functions MD5: f5b82fc35ec04109793ca78cafe8a6bc Size: 1.09 MB Download: http://adf.ly/1713566/sptdaio SCSI Pass Through Direct a.k.a SPTD v2.02 (Windows 10 x86/x64) Info: Optional, for advanced functions MD5: fe096f49fdc7f89822754378b8d4e34a Size: 439 KB Download: http://adf.ly/1713566/sptd2aio Website: http://www.duplexsecure.com
August 29, 201410 yr Awesome repak ricktendo. Is is also possible to disable the installation of the gadget that is included? (or maybe have a separate installer for that option disabled?)
August 29, 201410 yr Author Gadget is disabled by default, you have to check the box during end of setup if you want it to install (or am I mistaken?) BTW installer updated with same Prefrences as DT and also enabled Compact installation where only ENU language will be installed If anybody wants info on how to change these settings unattendedly just ask (tell me your desired settings) and I will show you how to achieve this More features will be added to the installer if I can com up with more to improve it
August 29, 201410 yr Author Added the option to NOT install DT.gadget and dependencies in program folder... Also Gadget is NOT offered nor does it install on Win8, only installs on Vista or Win7 I have also been working on adding file association options, but will not add this yet, this will take MUCH longer because I need help backing up previous associations using some sort of inno Code section (this is not my strong-suit) Let me know if removing DT.gadget/dependencies broke anything
February 27, 201510 yr Author This installer is allot more complicated since its both x86/x64 in one and I am backed up with vmware/virtualbox installers so this one should take some time to do
May 23, 20159 yr DAEMON Tools Lite 10.0.0.0053 is onlineChanges in DAEMON Tools Lite 10.0.0:* Brand-new design inspired by Windows 10* Upgraded Images catalog filled automatically* Numerous UI changes* Additional paid features available to try and buy separatelyThere is a chance for updates in your free time?
