Posted August 31, 201410 yr When i patch a Starter Edition.Export this 4 times.Change each to HOMEBASICHOMEPREMIUMPROFESSIONALULTIMATE Change 2 times name and 2 times description.Change the flag of each wim.Rebuild all 4 wim's. And then merge the 4 wim's with the WIM Manager to the Starter.All seams OK. But when i install,the lisense text is HOME BASIC.And when i do the complete install, the Edition is Home Basic, too.I can try every edition. Always the same. What is my error?
August 31, 201410 yr After you export/rename/reflag the images, you also have to mount each of them and update their edition:: Get a list of editions that can be updated todism /Image:D:\mount /Get-TargetEditions:: Set that edition (example, Windows 8 Pro to Pro with Media Center)dism /Image:D:\mount /Set-Edition:ProfessionalWMC
