This is applied to the win8.1 x64
When removing any metro apps I have this problem:
1. on startup screen, shortcuts are missing of other metro app that are not removed
2.  In photo metro app error is "Sorry, there was a problem please try again later",
3. Library does not exist, when I go to the option of a library 'File Explorer>View>Navigation pane>Show libraries', library generally does not appear,
            After enabling "Show libraries', then I got an error when I click on the File Explorer on the taskbar.
Surely if succeeded correctly display library first and second error will be eliminated!
How i can fix these errors?
I solved the problem for the second and third error option!
on clean install Win 8.1 removed the metro app, and then started integrating updates.
So probably were not in some way damaged metro applications.
error remain under Option 1, but it seems that it can not be fixed
So it seems best to remove Metro apps first?
The first error may be because when you normally remove a metro app. It says that others need to be removed also. Win Toolkit may just leave them which may cause the invalid shortcuts.
After processing this procedure 'on clean install Win 8.1 removed the metro app, and then started integrating updates'.
I checked it again and it works properly
for the first problem
when I remove only 'travel windows' then they are not removed from the startup screen shortcuts obviously working properly
when I remove any other metro app then being deleted all the shortcuts from the start screen
Edited by jigsaw5063
