Silent Install Switches
Hey guys, I'm currently adding a screen to show the silent install switch/syntax for common programs. If you have any programs which you know the silent install for can you please let me know.
So far:
.NET Framework 4.5: /passive /norestart
7zip: -y /q /r:n
AdobeAIR: -silent -eulaAccepted -desktopShortcut
Adobe Reader: /sPB /rs
Alcohol 120%: /qn
Avast Anti-Virus (free): /silent
AVIsynth: /S
AVStoDVD: /S
Burn Aware: /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP
Ccleaner: /S
CDBurnerXP: /NOCANDY /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
ClassicShell: /qn
Cyberfox: /Silent /TASKS="desktopicon,Install_Start_Menu_Icons"
Driver Easy: /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
ESET Smart Security: /qb /norestart
Firefox: /S /NCRC
Flash Player: -install
Google Chrome: --system-level
Google Chrome (Standalone): /silent /install
HashTab: /S
IconPackager: /s
Imgburn: /NOCANDY /S
Java Runtime Environment: /s /v/qn
Journal Viewer: /qn
IrfanView: /silent /desktop=1 /thumbs=1 /group=1 /allusers=1 /assoc=1
IrfanView-Plugin: /silent
Kazaa Codec Pack: /silent
LAVFilters:  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
Malwarebytes: /silent
Media Player Classic - BE:  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
Microsoft Office: /config %APP%\MyConfigPath.xml
Microsoft Security Essentials: /s
Notepad++: /S
nVidia Graphic Drivers: -s -n
PaintDotNET EXE: /createMsi CHECKFORBETAS=0 CHECKFORUPDATES=0 DESKTOPSHORTCUT=1 JPGPNGBMPEDITOR=0 PDNUPDATING=0 TGAEDITOR=0
PaintDotNET MSI: /passive /norestart
Partition Wizard Home Edition:  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
Perfect Disk: /qn
Piriform Defraggler:  /S
Open Office: /qn /norestart
RealPlayer: /s /v/qn
Realtek-HD-Audio: /s
Recuva:  /S
Revo Uninstaller: /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP
Shockwave: /S
Silverlight: /q /doNotRequireDRMPrompt /ignorewarnings
SkypeSetup: /VERYSILENT /nogoogle /noie /nolaunch
SoftPerfect-RamDisk:  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
Speccy:  /S
SpywareBlaster: /verysilent
SumatraPDF:  /s /register /opt plugin, pdffilter, pdfpreviewer
TeamViewer: /MSI /S
TeraCopy: /silent
Thunderbird: /S /NCRC
TuneUp Utilities: /q
VLC Media Player: /S
UnCleaner: /NOWINDOW
Windows 8 Manager: /q
WinISO: /VERYSILENT /SP-
WinRAR: /S
XMediaRecode:  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
Edited by Legolash2o
  • Replies 60
  • Views 68.7k
  • To help you a little bit with silent installers, let's get a bit more basic first.   When you install an app, any app,the default behavior is usually to do as you implied above - click Install, Next,
  • niTe_RiDeR_Pr0
    niTe_RiDeR_Pr0
    And, IDM (original) installer doesn't have a silent switch. You can use my repack (see the installer repacks section of the forum) & specify it's silent switch (/VERYSILENT /NORESTART /SUPPRESSMSG
  • I love that software, I use it and I got working addon   Dareckibmw_Theme_Resource_Changer_x64_v1.0.wa http://www8.zippyshare.com/v/31784111/file.html
May be you can post a spoiler of the programs you have already the silent switches for ;).
Anyway:
AdobeReader: /sPB /rs
AdobeAIR: -silent
ClassicShell: /qn (eventually /qn APPLICATIONFOLDER=C:\XYZ)
AIDA64: (/LOADINF=AIDA64.inf) /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
Firefox/Thunderbird: /S /NCRC
IrfanView: iviewxxx_setup.exe /silent /folder="c:\test folder\irfanview" /desktop=1 /thumbs=1 /group=1 /allusers=0 /assoc=1 /ini="%APPDATA%\irfanview"
PaintDotNET: a) <installer.exe> /createMsi CHECKFORBETAS=0 CHECKFORUPDATES=0 DESKTOPSHORTCUT=1 JPGPNGBMPEDITOR=0 PDNUPDATING=0 TGAEDITOR=0 (generiert x64 & x86)
                      b ) <PaintDotNet_xXX.msi> /passive /norestart
Realtek-HD-Audio: setup.exe /s /f2c:\mylog.log /z[-rpC:\RHDSetup.log] (extract the archive before!)
Shark007-Advanced: /S /v/qn (unzip the Advanced.exe before; if not ->>> undesired software)
TeamViewer: /MSI /S
Basically, if the installer allows the switches /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP- (see AIDA64) the user can try first to install the program on a running system with the switches
/SAVEINF="xyz.inf" /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-, selecting the options he wants, and then build the silent-installer (or put the switches in WTK)
/LOADINF="xyz" /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
Regards, Thiersee
Will that work with just the /silent? Basically without the /folder and /ini. I'd rather keep things simple as it's for beginners :)
P.S. I've already fixed the 'Malwarebytes' spelling bug :P
Yes, it does, but:
1) It doesn't set a desktop-link
2) The user has to set the options for every user
I think you can eliminate the switch /thumbs=1
BTW, I use this way, because I need to copy italian language files (english and german are default).
SkypeSetup - /VERYSILENT /nogoogle /noie
What for effect does have on Skype the switch /noie?
TNX, Thiersee
Edited by Thiersee
Ok everything that has been added and that has been mentioned is available to few in the first post. :)
I'm googling more!
TNX, Thiersee
; http://www.skype.com/go/getskype-full
; ALLUSERS=1 - install for all the windows users
; /NOIE - No Internet Explorer plugin
; /NOGOOGLE - No Google toolbar
; /verysilent - No installation interface
; /NORESTART - No restart
; /SP-
; /NOCANCEL cannot interrupt
;  /SUPPRESSMSGBOXES - avoid message boxes
; /NOLAUNCH' - doesn't start skype after installation
Is the hyphen needed?
Thiersee
AVIsynth http://sourceforge.net/projects/avisynth2/files/AviSynth%202.5/ :  /S
AVStoDVD https://sites.google.com/site/avstodvdmain/ :  /S
DVDStyler (Note: DVDStyler will try installing a crapware toolbar) http://www.dvdstyler.org/en/ :  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
ffdshow http://ffdshow-tryout.sourceforge.net/ :  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
Google-Chrome (Standalone-Setup) https://support.google.com/installer/answer/126299?hl=en : /silent /install
Haali Media Splitter http://haali.su/mkv/ :  /S /NCRC
ImgBurn 2.5.8 WITHOUT this f...... OpenCandy http://www.imgburn.com/index.php?act=download :  /NOCANDY /S
Inno-Setup http://www.jrsoftware.org/isdl.php :  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
LAVFilters https://github.com/Nevcairiel/LAVFilters/releases/tag/0.62 :  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
mkvtoolnix http://www.fosshub.com/MKVToolNix.html :  /S /NCRC
nVidia Graphic Drivers http://www.geforce.co.uk/drivers : First you have to extract downloaded setup with 7-zip. switch for setup.exe in extracted archive : -s -n
Partition Wizard Home Edition http://www.partitionwizard.com/free-partition-manager.html :  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
Piriform Defraggler / Recuva / Speccy https://www.piriform.com/products :  /S
SoftPerfect-RamDisk http://www.softperfect.com/products/ramdisk/ :  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
SumatraPDF http://blog.kowalczyk.info/software/sumatrapdf/free-pdf-reader.html :  /s /register /opt plugin, pdffilter, pdfpreviewer
XMediaRecode http://www.xmedia-recode.de/en/download.html :  /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-
Edited by Snow
ImgBurn 2.5.8 without this f...... opencandy :  /NOCANDY /S
Are you sure that ImgBurn installs OpenCandy?
CDBurnerXP installs it for sure, if you don't take the minimal_version (without OpenCandy).
Thiersee
UNCLEANER  -/NOWINDOW
ESET SMART SECURITY  -/qb /norestart
Revo Uninstaller- /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP
Burn Aware - /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP
A little note to burnaware-free : it will be installing a toolbar. my workaround for this: extract it with universal-extractor, delete the temp folder inside the extracted setup, then edit install.iss and compile it with inno-setup.
You can do also this way (just tested):
1) install in a VM with the switch /SAVEINF=burnaware.inf and user-defined installation
2) untick the option for the Toolbar
3 finish the installation
To make it silent:
1) installer & burnaware.inf in a folder
2) in WTK thick the option "Copy Folder" and put "/LOADINF=burnaware.inf" as 1st switch then the other switches.
Thiersee
Thanks for the tip. I will test it now.
BTW:
you can try this tip with every installer accepting the switches /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-.
There is only one problem: not every installer read out the inf.
normally I just create a bat file to run the exe with /? and it shows switches, however I found this: www.checkdevice.narod.ru/index/skf/0-36. to find the swiches.
Edited by techbound
Test 3 has been released with more applications added......
Thanks, but you forgot 1 line for PaintDot.NET
The first line is only to extract the .MSI-file with NO INSTALL!
Thiersee
