Posted September 8, 201410 yr Z3R07's NT6 USB 3.0 Driver Pack Update:I decided to delete my project.The reason is, it exist a much better and more up2date pack.I recommend to registrate and download DriverPackSolution:http://drp.su/download.htm Methode Install (HowTo):1. Download and extract this useful tool: http://www.mediafire.com/download/resi18rkv626mfr/SAD3-130825.7z2. Create folder D in NT6\x64 and extract the content of the DriverPack to the NT6\x64\D\ folder so that the folder heirarchy looks like this: \NT6\x64\D\*.3. Start DP_Install_Tool.cmd and follow instructions. Greetings,Zer0 Edited March 20, 20159 yr by Z3R07
September 8, 201410 yr Author Please, if you can, help me to find dupplicates/outdates.Or if you find any newer version which do superseding.After i collect some i clean and remake the pack. Edited September 8, 201410 yr by BrokenZer0
September 11, 201410 yr Thanks.Can we use the with DP_Install_Tool.cmd or it is only to be used with WTK ?
September 11, 201410 yr Author I think DP_Install_Tool.cmd depens on the using of dpinst.exe. (parameters for silent or something? I dont know the batchfile)I recommend to use dpinst.exe directly on rootfolder of all driverfolders and let it install missing drivers.Sometimes windows install standard driver for some hardware, then you will need to remove them before. By integrating i recommend to integrate all drivers first, then backup the really used drivers and integrate these into a new image. Greez
