I used Unattended Creator in the past for my Win7 Home Premium installation. After generation of the XML I added some extra locale info, so I did not have to make selections for that during install. For my Win 8.1 installation I took the existing Win7 XML, updated the serial and the image name to be used, and presto, everything worked. Note that this was done with an older version of WTK 1.4.1.27.
Or did you mean using the current version of Unattended Creator?
Regards, Eric666
