Hello sorry to bother you again giving me the following error
Saturday 20 September 2014 18:44:53 PM +02:00 Hora estándar romance
Log ID: 1x9F5A8D0AFE3A6687620FAB17D44E3D73_Ex06004651_frmAllInOne_es-ES_609769
NOTE: Use the 'Log ID' when referring to your issue on the forum.
It will allow me to find your log and have a look at the problem easier.
***BASIC***
Error in main integration
***EXTENDED***
WINDOWS 7 ULTIMATE X64 BY RENOVATIOSOFT
Checking if registry needs loading...
1
***EXCEPTION***
InvalidArgument=El valor de '3' no es válido para 'index'.
Nombre del parámetro: index
InnerException:
Source: System.Windows.Forms
TargetSite: ListViewSubItem get_Item(Int32)
***WINTOOLKIT INFO***
Win Toolkit v1.5.0.17
Win Toolkit Directory: C:\Users\Arkangelo\Desktop
Anti-Virus: False
User Temp Path: C:\Windows\WinToolkit_Temp
WTK Temp Path: C:\Windows\WinToolkit_Temp
Open Forms: frmAllInOne
Form History: frmStartup, frmToolsManager, frmWelcome, frmWIMManager, frmAllInOne, frmAIOPresetManager, frmTweaks, frmTweaks, frmAIOPresetName
***COMPUTER INFO***
System Directory: C:\Windows\system32
DISM Location: C:\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe
DISM Version: 6.3.9600.16384 (winblue_rtm.130821-1623)Microsoft Windows NT 6.1.7601 Service Pack 1 (es-ES)
Windows 7 Ultimate (64-bit)
7601.18409.amd64fre.win7sp1_gdr.140303-2144
Resolution: W 1366 H 768 D 32
CPU:
Name- Intel® Core™ i7-3630QM CPU @ 2.40GHz
Speed- 2401Mhz / 2401Mhz
Cores- 4 / 8
Status- 2% OK
Physical Memory: 1.420 MB / 4.047 MB (2.626 MB Free)
Virtual Memory : 1.373 MB / 8.092 MB (6.719 MB Free)
Drives
C:\ Fix NTFS 157,89 GB  / 218,59 GB
D:\ Fix NTFS 68,51 GB  / 104,28 GB
F:\ Fix NTFS 130,64 GB  / 142,79 GB
G:\ CDR UDF 0 bytes  / 2,85 GB w7
***OPTIONS***
fAddons=C:\Users\Arkangelo\Desktop\addons
fThemes=C:\Users\Arkangelo\Desktop\temas\tema red
sMountTemp=C:\WinToolkit_Mount
sAddRunOnce=True
sAICommands=True
sAVScan=True
sAIOSave=True
sUpdFilter=True
sPreventSleep=True
sCheckForUpdates=True
sDLogging=True
sDISMUpdate=True
sFreeRAM=True
sLastDir=C:\Users\Arkangelo\Desktop
sLastWIM=C:\w7\sources\install.wim
sPLastWIM=C:\w7\sources\install.wim|N/A|N/A|N/A|N/A
sDeleteMount=True
smCheck=False
sAIOPM=True
sQuickMerge=True
sFormSize=|frmWIMManager:1123*350
smVerify=False
sSolDownload=C:\Users\Arkangelo\Desktop\Updates\
sTransparency=100
sTransparencyAll=False
sWinToolkitDISM=Normal
sWinToolkitExt=Normal
sWinToolkitPRI=Normal
sUploadLogs=True
sMountLog=True
sShowWelcome=False
sRegistryLog=False
***STACK***
get_GetStackTrace
PrepareLog
Save
Upload
BWRun_DoWork
WorkerThreadStart
_PrivateProcessMessage
AsyncProcessMessage
ThreadPoolCallBack
runTryCode
ExecuteCodeWithGuaranteedCleanup
Run
PerformWaitCallbackInternal
PerformWaitCallback
***RAW_STACK***
   en System.Windows.Forms.ListViewItem.ListViewSubItemCollection.get_Item(Int32 index)
   en WinToolkit.frmAllInOne.BWRun_DoWork(Object sender, DoWorkEventArgs e)
***RAW_EXCEPTION***
System.ArgumentOutOfRangeException: InvalidArgument=El valor de '3' no es válido para 'index'.
I haven't test 18, but 19 crashes as well
Description:  Stopped workingProblem signature:  Problem Event Name:	CLR20r3  Problem Signature 01:	wintoolkit.exe  Problem Signature 02:	1.5.0.19  Problem Signature 03:	541df33d  Problem Signature 04:	WinToolkit  Problem Signature 05:	1.5.0.19  Problem Signature 06:	541df33d  Problem Signature 07:	4c8  Problem Signature 08:	3a  Problem Signature 09:	System.TypeInitialization  OS Version:	6.1.7601.2.1.0.256.48  Locale ID:	1033Read our privacy statement online:  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409If the online privacy statement is not available, please read our privacy statement offline:  C:\Windows\system32\en-US\erofflps.txt
