Posted September 20, 201410 yr Popular Post Description:The Visual C++ Redistributable Packages install runtime components that are required to run applications that are developed by using Visual Studio. These packages install run-time components of these libraries: C Runtime (CRT), Standard C++, ATL, MFC, C++ AMP, OpenMP and MSDIA. read more.OS: Windows AllVersions:VC++ 2022: 14.44.35026.0 VC++ 2013: 12.0.40664.0 VC++ 2012: 11.0.61135.400 VC++ 2010: 10.0.40219.473 VC++ 2008: 9.0.30729.7523 VC++ 2005: 8.0.61187 VC++ 2003: 7.10.6119.0 Vc++ 2002: 7.0.9975.0 + Legacy Visual Basic RuntimesFiles Contents:vcredist_x64_Win7 / vcredist_x86_Win7: All runtimes for Windows 7 SP1 vcredist_x64_2022_WinAll / vcredist_x86_2022_WinAll: Visual C++ 2022 vcredist_x64_2013d_WinAll / vcredist_x86_2013d_WinAll: Visual C++ 2013, 2012, 2010, 2003, 2002 Visual Basic 6.0 Runtimes vcredist_x64_SxS_Win7 / vcredist_x86_SxS_Win7: Visual C++ 2008, 2005 for Windows 7 SP1 vcredist_x64_SxS_Win810 / vcredist_x86_SxS_Win810: Visual C++ 2008, 2005 for Windows 8.1/10Important Notes:# Integrating SxS 2008/2005 addons require launching Wintoolkit with TrustedInstaller privileges, to gain write access to WinSxS directoryfor that, you need to use NSudo (or other similar tools):- download and extract latest release Binary.zip- launch Win32\NSudo.exe or x64\NSudo.exe, or run NSudo.bat as administrator- make sure User is set to TrustedInstaller- check "Enable All Privileges"- paste Wintoolkit.exe path in the lower box (or Browse to the file)- click runif you are using Windows 7 Simplix Update Pack, you don't need that, it already handle the required privileges# vcredist_x64_Win7 / vcredist_x86_Win7 is AIO addon, mainly to be used with Simplix Update Pack, or else you need Wintoolkit with NSudo# VC++ 2022 runtimes are binary compatible and upgrade to VC++ 2015-2017-2019 and cover all VS 2015-2017-2019-2022 programs# To complete VC++ 2022 functions for Windows 7/8.1, you need to integrate Universal CRT components, which is available with latest Monthly Rollup, or updates KB3118401/KB2999226Download:vcredist_x64_Win7_20250408.WAvcredist_x86_Win7_20250408.WAvcredist_x64_2022_WinAll_14.44.35026.WAvcredist_x86_2022_WinAll_14.44.35026.WAvcredist_x64_2013d_WinAll.WAvcredist_x86_2013d_WinAll.WAvcredist_x64_SxS_Win7.WAvcredist_x86_SxS_Win7.WAvcredist_x64_SxS_Win810.WAvcredist_x86_SxS_Win810.WAyou can find latest releases -> hereSHA1 checksums:05e938f354c059d89d846d2e9a7591d05154aa70 *vcredist_x64_2013d_WinAll.WA 534f1e53080819aeb58e3b060d7c6a0a76b4d4d4 *vcredist_x86_2013d_WinAll.WA 8cc9f65fc444a878d8cabd0ad317597edb552f07 *vcredist_x64_SxS_Win7.WA 886faa949e7d51a40dc8d467f65c373f887c2ec3 *vcredist_x86_SxS_Win7.WA 94e267e5e6ff89854bd64b6260333664a266c754 *vcredist_x64_SxS_Win810.WA 206fda69fa2d3fd838dd9e3ee33f35c4cd7a2cae *vcredist_x86_SxS_Win810.WA Credits to ricktendo for original repack AIO Edited April 8Apr 8 by abbodi1406
February 28, 20196 yr Author Project Rebooted make sure to read the notes, specially about SxS 2008/2005 addons i kept 2017 addon separate so it can be easily updated
March 1, 20196 yr Thank you! I'm starting to test, so far I checked x86. 1) In the Uninstall section "2010 x86" has 2 spaces. "DisplayName"="Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219" 2) No icons in many entries. Pic1 what is it seen, Pic2 how can it be. 3) I think the changes between SxS_Win7 and SxS_Win810 are too small to make different addons. 4) A few errors in the entries: vcredist_x86_SxS_Win7\VC_x86_2005.reg in Components\x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.6229_none_cbee8c4a4710d003 has "\" in "f!mfc80u.dll" and "f!mfcm80.dll". vcredist_x86_SxS_Win7\VC_x86_2008.reg in Components\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.7523_none_4bf3b680bf9ea69d has "\" in "f!mfc90u.dll" and "f!mfcm90.dll". 1-3 items are not critical. P. S. Checked x64 - all the same. Edited March 1, 20196 yr by simplix
March 2, 20196 yr Author 1) The two speces are the default state from original installer 2) i use slim msi installers for all vcredist, msi entries do not have display icon by default https://github.com/abbodi1406/vcredist using original installers (specially 2017/2013/2012) will add many bloat files and registy: https://forums.mydigitallife.net/posts/1472819/ i could add custom display icon for each msi file (similar to .NET addon), but i'm trying to keep things minimal and default as much as possible 3) actually, upon further tsting, there are more diffirent registry values in COMPONENTS keys i will update Win810 addons 4) thanks for notifying, SxS entries are hard to keep an eye on i will fix that ASAP
March 2, 20196 yr 1) The two speces are the default state from original installer 2) i use slim msi installers for all vcredist, msi entries do not have display icon by default https://github.com/abbodi1406/vcredist using original installers (specially 2017/2013/2012) will add many bloat files and registy: https://forums.mydigitallife.net/posts/1472819/ i could add custom display icon for each msi file (similar to .NET addon), but i'm trying to keep things minimal and default as much as possible 3) actually, upon further tsting, there are more diffirent registry values in COMPONENTS keys i will update Win810 addons 4) thanks for notifying, SxS entries are hard to keep an eye on i will fix that ASAP abbodi1406, thank you for your work. Please retreat from your principles, use the icons. Since without them, it seems that the file is damaged.
March 3, 20196 yr А зачем в одном из аддонов папки DESIGNER? And why in one of DESIGNER folder add-ons?
March 3, 20196 yr More like "Why is there a "DESIGNER" folder in one of the addons?". А зачем в одном из аддонов папки DESIGNER? And why in one of DESIGNER folder add-ons?
March 3, 20196 yr Author Jan Krohn Thank you @Pavel DESIGNER is part of Visual Basic 6 runtimes You must start Wintoolkit as TrustedInstaller. Read the Important Note again
March 3, 20196 yr Jan Krohn Thank you @Pavel DESIGNER is part of Visual Basic 6 runtimes Уже переделал. Забыл про инструкцию, где необходимо получить права на доступ к этой папке. Спасибо. Already remade. Forgot about the instruction where it is necessary to acquire the rights for access to this folder. Thanks.
March 5, 20196 yr Do x64 users need to install the x86 as well? Or just the x64? Sorry if it seems obvious but I seem to recall some x64 progs still use x86 runtimes?
March 5, 20196 yr Do x64 users need to install the x86 as well? Or just the x64? Sorry if it seems obvious but I seem to recall some x64 progs still use x86 runtimes? в 64 аддоне уже есть и 32 in the 64th add-on there are already also 32
March 13, 20196 yr Почему так выглядит не одинаково? Без иконок было красивее. Сейчас не пойми что. Лучше сделать или как было, или сделать все иконки голубенькие как у 2012 - 2017. Why so looks not equally? Without icons it was more beautiful. Now do not understand that. It is better to make or as was, or to make all icons blue as at 2012 - 2017. Edited March 13, 20196 yr by Pavel
March 14, 20196 yr 20 hours ago, Pavel said: Почему так выглядит не одинаково? Без иконок было красивее. Сейчас не пойми что. Лучше сделать или как было, или сделать все иконки голубенькие как у 2012 - 2017. Why so looks not equally? Without icons it was more beautiful. Now do not understand that. It is better to make or as was, or to make all icons blue as at 2012 - 2017. Pavel, Вы не правы, Вот свойства оригинального файла. Иконку хорошо видно? А если автор сделает как Вы просите, действительно будет "не пойми что". Pavel, you are wrong, here are the properties of the original file. The icon is clearly visible ? And if the author does what you ask, it really will be "do not understand that." abbodi1406, thank you so much for the icons! Edited March 14, 20196 yr by lukalex
March 14, 20196 yr I know as fitters of an old and new look look, but old fitters do not put an icon at all, and the author added so already discrepancy. Therefore it is better or without icons, or to make all identical having taken directly from the .MSI file. I already remade its add-ons having replaced old icons from new of it - add-ons. In a word does not look at all, and the design is necessary everywhere where it is possible to make.
March 14, 20196 yr 10 hours ago, lukalex said: Pavel, Вы не правы, Вот свойства оригинального файла. Иконку хорошо видно? А если автор сделает как Вы просите, действительно будет "не пойми что". Pavel, you are wrong, here are the properties of the original file. The icon is clearly visible ? And if the author does what you ask, it really will be "do not understand that." abbodi1406, thank you so much for the icons! ---------------------------------------------------------------------------------------- Супер. Super 10 hours ago, lukalex said:
March 18, 20196 yr Народ, подскажите поточнее какие пакеты аддонов Visual++ без проблем подойдут для Windows 8.1? The people, prompt more precisely what packages of add-ons Visual without problems will be suitable for Windows 8.1?
