Hi Lego,
I need your help.
On installing Win7- Prof or HP x64 (italian) with the two versions in one ISO I get following error after installing (VM)
and I don't know, if it's a mistake of mine or a bug.
To the ISO:
1st step
Prof and HomePremium together, no errors on integrating; on making ISO date of modified install.wim selected; generated with Test5.
2nd step
Prof or HomePremium (different autounattend.xml and drivers), no errors on integrating; on making ISO date of modified install.wim selected; generated with Test6.
For HomePremium DE x86 and Prof DE x64, both single version-ISO, no issue.
Do you have an hint, where I can begin to search?
I could try with version 1.5.1.2 and without changing the date on making ISO, but it's an long and annoying job, with two PCs too.
Thanks a lot.
Thiersee
Edited by Thiersee
Maybe an update caused it.
I can't believe that: if I install with the ISO after step 1 (only updates) I do not get the issue.
.... I have however fixed a bug which may have caused it so just wait for the next test build.
Let see...
Thiersee
Hi Lego,
sorry if it tokes longer to report.
I must have made a big mistake, but I don't know where and what :sad02:!
Anyway I tried again twice with absolutely the same settings-, .INI-, updates-files and it works for my satisfaction /Test 8).
Regards, Thiersee
Edited by Thiersee
