Posted September 26, 201410 yr Just though I'd let you know that the exclusive downloads will not be working. I am currently uploading new ones
September 27, 201410 yr Just though I'd let you know that the exclusive downloads will not be working. I am currently uploading new ones thanks
September 27, 201410 yr The exclusive section is locked. Even though I have my reg info on this computer.
November 22, 201410 yr So how do I gain access to exclusive ISOs? I have loaded a regkey that came after donation, but I still get this:
November 22, 201410 yr Ugh, sorry, my bad, I was experimenting with Faronics and managed to screw something up with my registry... fixed it now and it loads up everything now
November 22, 201410 yr There is a modded version with net framework preinstalled or integrated... And I am using these ISOs on virtual machines for various testings and experiments...I love you very much for this
June 30, 20159 yr Hi, I've just subscribed and was looking to get access to the exclusive ISO downloads, can you please tell me how I go about getting a key? Thanks
June 30, 20159 yr Keys do not come with these. These are just updated iso images to use with your own key.
June 30, 20159 yr He might have been talking about getting a "key" to have access to download them, in which case the answer is that he has to donate. Cheers and Regards
June 30, 20159 yr He might have been talking about getting a "key" to have access to download them, in which case the answer is that he has to donate. Cheers and Regards Hi, yeah that's what I meant. I donated and now am a member but I wasn't sure how I get a key to access the downloads. Hello everyone btw!
July 1, 20159 yr Welcome to WinCert! Hi, yeah that's what I meant. I donated and now am a member but I wasn't sure how I get a key to access the downloads."member"? We're glad you're now a member of WinCert, but for the access you are looking for you need to donate specifically to Win Toolkit, using the "Donate" button on the Win Toolkit tool itself.Cheers and Regards
