Posted September 29, 201410 yr Hi ; Test ; WinToolkit_1.5.3.20_Experimental2015-04-23_23-39-PM.ini Edited April 24, 20159 yr by rulman
September 29, 201410 yr Do you have a link to the driver(s) please? EDIT: OH wait, it didn't integrate any?????????//
September 29, 201410 yr Author İntel win64_15363 4th Generation Intel® Core™ Processors 5200-5100-5000-4600-4400-4200Intel win64_152822 2nd Generation Intel® Core™ Processors with Intel® HD Graphics 30002000Intel win64_153322 3rd Generation Intel® Core™ Processors with Intel® HD Graphics 40002500Qualcomm Atheros AR9xxx 10.0.0.285 [ 7.3.2014 ]Qualcomm_Atheros_Bluetooth_Suite_8.0.1.320Realtek Ethernet Controller Driver 7.089-8.35Realtek Win7_Win8_Win81_R275 Any not integrated This ımage ; http://uppix.com/f-Ads__z15429a12e0017b3a6.png
September 30, 201410 yr Author http://uppix.com/f-Update542a51300017b4df.pngWinToolkit_1.5.2.7C_Portable ??Settings.txt
October 4, 201410 yr With the image mounted can you please type the following command (CMD with admin)DISM /Image:C:\YourMountPath /Get-Drivers /Format:Table >C:\Drivers.txtand then attatch C:\Drivers.txt
October 4, 201410 yr Author http://uppix.com/f-Ads__z54301f910017c1d0.pnghttp://uppix.com/f-154301f6c0017c1ce.pngeroor.txtDrivers.txt
October 4, 201410 yr According to the Drivers.txt the drivers have been integrated. I have no idea what I'm supposed to be looking for on the second image with updates. EDIT: You haven't posted your Last_Session.ini
October 5, 201410 yr Author What is it about the order integratedhttp://uppix.com/f-Ads__z54301f910017c1d0.png2014-10-04_22-42-PM.ini
October 7, 201410 yr Author @Legolash2o;First Intel Onboard Driver Second Nvidia 620M Notebook DriverDriver ; Nvidia Driver Integrate but Not Install
October 18, 201410 yr Author @legolash2o WinToolkit_1.5.2.11_Portable Driver Integrate invisible¿What is the reason for this?Solutions come?
October 23, 201410 yr That time I asked you to run DISM /Image ..... /Get-Drivers... You need to do the same thing but for updates please. DISM /Image:[path] /Get-Packages /Format:table > C:\Updates.txt then attach updates.txt
October 30, 201410 yr Author @Legolash2ohttp://postimg.org/image/ct1to4hvt/full/ Does not Work ; WinToolkit_1.5.3.2_Portable Driver added butinvisible2014-10-30_00-21-AM.iniDrivers.txtUpdates.txt
December 8, 201410 yr Author @Legolash2o WinToolkit_1.5.3.5_Portable is not work ( Driver's Tab Invisible )CurrentEdition.txtDrivers.txtPackages.txt Edited December 8, 201410 yr by rulman
December 22, 201410 yr I reckon the drivers one could be fixed pretty quickly if you we had a TeamViewer session
January 15, 201510 yr rulmanMake a backup of the drivers from the host to the folder from the same folder with the integrated. This folder are not moved or copied, it will be errors in integration. Edited January 15, 201510 yr by stas33
January 15, 201510 yr Author @stas33 You may be right butIn previous versions it was not such a problem01_Intel202_Intel303_Intel504_Atheros AR9xxx 10.0.0.30205_Atheros_Bluetooth07_Realtek_HD_6.01.740909_Realtek_Lan_7.089-8.35
