Can you make support for DriverGrabber 2.0 http://integrator.professorcpu.net/index.php?addons&id=242 ... And lets earching for drivers filename in the root of the folder the drivers get integrated from?
Example now is when i use drivergrabber 2.0 to get all my drivers from the current windows, if i then want to integrate them with win toolkit, many of the files/drivers will not be integrated because "i think" win toolkit looks for sub folders where the drivers would normally be  stored and if not found hole specific drivers are interruted/failed,
with drivergrabber 2.0 all native/core files for the respective hardware/drivers are in the same folder under each name but without sub folders. Hope you understand ;)
The program with this is that it would require third party tools which I'm trying to move away from. However I may look into programming my own tool to backup drivers.
