CATEGORY: Adobe Runtimes/AiOs
ABOUT: Adobe Flash Player v21.0.0.242 & v22.0.0.168beta (PPAPI+NPAPI Plugin & ActiveX) + Shockwave Player 12.2.4.194 + Adobe AIR v21.0.0.215 & v22.0.0.149beta Runtimes --> All-in-One RePack. [13.6.2016]
nSj1oWb.png?1 + YSnGudU.png + VtdfftG.jpg?1
Quote
About The Programs:
Adobe Flash Player: Adobe Flash Player is the standard for delivering high-impact, rich Web content. Designs, animation, and application user interfaces are deployed immediately across all browsers and platforms, attracting and engaging users with a rich Web experience.
Adobe Shockwave Player: Shockwave Player is the web standard for powerful multimedia playback. The Shockwave Player allows you to view interactive web content like games, business presentations, entertainment, and advertisements from your web browser.
Adobe AIR: Adobe Integrated Runtime (Adobe AIR) is a runtime which enables to view/run web-based desktop apps (java,etc.) on the PC desktop easily.
INFO/NOTES:
  • You can select which runtimes to install in the setup wizard.
  • Shockwave player original msi installer repacked by me to slim it up (better compression, LZMA2).
  • Removed Shockwave Player 10 compatibility files.
  • NEW: Also added beta version AiO, containing latest beta versions of the runtimes.
  • Updated on 13 June 2016.
Quote
Command-Line Parameters(Switches & Options):
Usage:                      AdobeRuntimes_AiO.(13.6.2016).exe [switches]
                                                     All switches are optional.
Switches:
Spoiler
/SILENT: Passive installation, shows only installation progress. NO user input required. Installs ALL packages.
/VERYSILENT: Fully silent installation, shows no GUI at all. NO user input required. Installs ALL packages.
/NORESTART: Prevents setup from restarting after a successful installation.
/SUPPRESSMSGBOXES: Instructs setup to suppress(remove) message boxes. Only effective when used with /SILENT or /VERYSILENT switch.
/LOG: Caused setup to make a log file in the User's temporary directory (Mostly the temporary directory is at "%USERPROFILE%\AppData\Local\Temp").
/COMPONENTS="name of components separated by a comma": Tells setup which runtimes to install. In this setup the component names are: flashplugin (Flash Player PPAPI Plugin), fkashpplugin(Flash Player PPAPI plugin), flashactivex (Flash Player activex), shockwave (Shockwave Player) & air (Adobe AIR).
Examples:
Spoiler
  • Install All the runtimes silently by showing only progress (passive mode), without restarting automatically and create a log:
    AdobeRuntimes_AiO-_-niTe_RiDeR-(May5.2015).exe /SILENT /NORESTART /SUPPRESSMSGBOXES /LOG /SP-
  • Install Flash Player ActiveX & Plugin only, fully silently without restarting automatically:
    AdobeRuntimes_AiO-_-niTe_RiDeR-(May5.2015).exe /VERYSILENT /NORESTART /SUPPRESSMSGBOXES /COMPONENTS="flashplugin,flashactivex" /SP-
DOWNLOADS:
Stable version: https://mega.nz/#!poRT2LxJ!KnikLatcxudi2HO3snwUhXbf6N5VRAG2IsuEdgVveqU
Beta version: https://mega.nz/#!15QxRRZJ!W2ROf4zgxhLi2rVtOzUdazdMGkKKxVQw-mu9hWINsFA
Architecture: x86 & x64
VirusTotal Scan Report: Will be uploading later, but I am sure it is 100% safe.
Enjoy! :)
Cheers... ;)
Edited by niTe_RiDeR_Pr0
updated
  • Replies 73
  • Views 42.4k
  • Adobe AIR has not been installed (VirtualBox Win7 Prof x64), AdobeFlash 15.0.0.189 released.   TNX, Thiersee
  • niTe_RiDeR_Pr0
    niTe_RiDeR_Pr0
    I have fixed and updated the AIO.   Regards, niTe_RiDeR
  • Adobe Flash Player 15.0.0.223 http://fpdownload.adobe.com/get/flashplayer/pdc/15.0.0.223/install_flash_player_ax.exe http://fpdownload.adobe.com/get/flashplayer/pdc/15.0.0.223/install_flash_player.exe
I have fixed and updated the AIO. :)
Thanks for fixing and updating!
1 small "cosmetic" bug is still present:
the installer leaves a temp-folder in the same path where the installer is; it should not, if possible.
Thiersee
Edited by Thiersee
Thiersee
Thanks for reporting!
Currently Fixing & Uploading...
Fixed on October 17 - 12:03 PM IST! :) :thumbsup:
Regards,
niTe_RiDeR
Edited by niTe_RiDeR_Pro
If there will be a new update, please report me by commenting here. I will update it. :) I dont have the time to always check for new updates...  Please co-operate with me....  ^_^
can't install any of the programs like flash or shockwave or adobe air the error message is create process failed code2 this is on a win7 x64 bit English system. thanks so much.
thanks for reporting :thumbsup:
sorry! seems like a coding error, I am gonna fix & update it :)
I will be uploading it today..
BTW I like this forum & its members who are much co-operative & helpful :D
Can someone pls host this file on tusfile or other resumable sites pls ... I can't download from this link
@neoxcool, I wont upload it to tusfiles because its full of ads & its deleted when nobody downloads the file for 30 days; and my repacks are not much famous that it gets downloaded once/more times every week, like ricktendo's runtime repacks...
BTW my future repacks and new updates to my exisisting repacks (like this one, Im gonna update it today) will be hosted on MEGA (mega.co.nz). So if you want better download speed use the MEGA extension for chrome or MEGA extension for firefox. ;)
Regards,
niTe_RiDeR
I have found out one more update:
Shockwave Player has been updated to v12.1.4.154... http://filehippo.com/download_shockwave
Done! I have:
  • Made some changes in the GUI
  • Updated Flash Player Plugin & ActiveX to v15.0.0.223
  • Updated Shockwave Player to v12.1.4.154
  • Updated Adobe AIR to v15.0.0.356
  • Fixed the code2 create process execution error
Hi niTe_RiDeR,
two bugs in the new version:
1) Flash Player Plugin does NOT install
2) During Shockwave installation Chome-Install-Box appears and must be confirmed (with or without Chrome)
Silent-mode used.
Regards, Thiersee
Hi niTe_RiDeR,
But, Yes it installs in mine. Maybe, at the time of install chrome/firefox might be running. So the setup may require restarting of chrome/firefox
Thanks, I will fix it and will be uploading it today... ;)
Hi niTe_RiDeR,
fixed everything. :)
Note-Replaced crappy exe (it had some useless norton/google toolbar) with the msi.
No, it doesn't and I don't use chrome.
VirtualBox, Win7 Prof, x64 italian.
Edit:
x86 HomePremium german the same: no plugin install.
Edited by Thiersee
Sorry, I re-downloaded the file but Flash Plugin is still NOT installing, Firefox is NOT running!
Thiersee
Sorry! @Dziubek had given me wrong link of the plugin (it wasnt working). The actual link is this: http://download.macromedia.com/get/flashplayer/current/licensing/win/install_flash_player_15_plugin.exeSo I will fix & upload... ;)
currently uploading...
