I've been searching the forums for an answer to this question, but without any luck.
From these two AIO tabs, which comes first when deploying, the silent installs or the files tab? I want to install a program with a silent installer and then change some files within its folder. Will this be possible.
Thank you very much.
Files comes first, silent-installers will be installed after the first login.
You can pack the installers in an SFX-file together with the files you will change and a batch/cmd-file copying those files in the right place.
Thiersee
