Posted October 25, 201410 yr Foxit Reader - v7.0.3.916by niTe_RiDeR_Pro About The Program:Whether you're a consumer, business, government agency, or educational organization, you need to read, create, sign, and annotate (comment on) PDF documents and fill out PDF forms. Foxit Reader is a small, lightning fast, and feature rich PDF viewer which allows you to create (free PDF creation), open, view, sign, and print any PDF file. Foxit Reader is built upon the industry’s fastest and most accurate (high fidelity) PDF rendering engine, providing users with the best PDF viewing and printing experience. Available in English, Dutch, French, German, Italian, Portuguese, Russian, and Spanish.PDF Viewer - Lighting fast PDF view and print of PDF files and portfolios quickly without exhausting system resources.Easily View Multiple PDF Files - Multi-tab style document display allows users to go back and forth between different PDF documents quickly and easily.Configurable PDF Viewer - Configure document views with read mode, reverse view, and text viewer options. Configure page display with full screen, single page, continuous scrolling, split, two page facing, continuous facing, separate cover page, auto-scroll, and page transition options.Bookmark Support - Easily add, edit, and modify bookmarks in a PDF document.Multiple Views - Rotate pages between landscape and portrait. Configure zooming or adjust magnification using the marquee, loupe, and magnifier tools. (Hosted on Google Drive)Architecture: x86 ONLYFile Size: 25.7 MBSHA-1 Checksum: 914A80A7B73B52F3D25CDFF9A46BC1083273FB07MD5 Checksum: 20033E9F8A014E41B69A99E044C6B4BCSHA-256 Checksum: DBEEE6AB5A7FA902D1FEE6FAC011F2D0E26F591ACB6F059396A06F5ABF208770 Enjoy! :thumbsup: :icon_cool: Edited November 6, 201410 yr by niTe_RiDeR_Pro
October 29, 201410 yr None of your addons are "dual" addons.... The "dual" term in the task.txt file is used when you have a addon that installs using a .inf file..... You need to change the "dual" to "x86!" Because these will only work correctly on a x86 systems.... On x64 systems there will be TONS of registry entries that are wrong... Edited October 29, 201410 yr by *Reaper*
October 29, 201410 yr Author None of your addons are "dual" addons....The "dual" term in the task.txt file is used when you have a addon that installs using a .inf file.....You need to change the "dual" to "x86!"Because these will only work correctly on a x86 systems....On x64 systems there will be TONS of registry entries that are wrong... Oh, Thanks for your feedback and reporting! I am just a beginner right now... In the tasks.txt file I will change 'dual' to 'x86'.And, please check your PM. Currently my internet data usage limit is over and Iam having very slow internet speed. After I renew my connection (and get full speed), I will be uploading fixed version. (probably next month). :newhere: Edited October 29, 201410 yr by niTe_RiDeR_Pro
