Kelsenellenelvian Posted October 27, 2014 Posted October 27, 2014 OK Thanks for the tip I will remember to not download updates then. Quote
arkangelo22 Posted October 27, 2014 Author Posted October 27, 2014 I am referring to when using Alfawaves Downloader is looking for and does not download updates any solution? Quote
Kelsenellenelvian Posted October 27, 2014 Posted October 27, 2014 Well see my crystal ball is broken and you are providing nearly NO information. I will summon the information demons and see if they will provide me with the rest of the info I need to actually help you since you seem to be unable to provide even the most basic of information such as operating system used, if your av is active, what version of alpha's you are using and such. Don't hold your hopes out though I don't have much for the sacrifices required.... Quote
arkangelo22 Posted October 27, 2014 Author Posted October 27, 2014 Well see my crystal ball is broken and you are providing nearly NO information. I will summon the information demons and see if they will provide me with the rest of the info I need to actually help you since you seem to be unable to provide even the most basic of information such as operating system used, if your av is active, what version of alpha's you are using and such. Don't hold your hopes out though I don't have much for the sacrifices required....I am using WinToolkit_1.5.2.13_Portable but happens to me with the earlier versions also remains loading and hence does not pass Quote
Kelsenellenelvian Posted October 27, 2014 Posted October 27, 2014 We cannot help you without more information! Answer the following or I will just close your thread: Are you running with a antivirus or anti-malware running?Are you using the toolkit on a company network at all?Did you run the toolkit as a admin and are you on a non limited account?WHERE EXACTLY does the down-loader freeze? A screenshot would be handy here. Quote
