Posted October 27, 201410 yr Lego you had mention previously that if I created a "drivers" folder in the root or" sources\\drivers" that the RunOnce would scan and install only whats needed but I am not quite sure how to actually create the RunOnce for this process. Do I use WTK to "integrate the drivers or is it another method. Any help would be appreciated.
October 27, 201410 yr Assuming you've mounted the image at least once. You just copy and paste the drivers into sources\\drivers folder.
October 28, 201410 yr Author So I mount the image via DISM or WTK, create a "drivers" folder in the sources folder, add my drivers (in a single folder or subfolders?) then unmount/save, create an ISO and do an install? Will that install the drivers? OR Mount the image with WTK, create a "drivers" folder in the sources folder, add my drivers (in a single folder or subfolders?) then unmount/save, create an ISO and do an install... WTK created a RunOnce that recognizes the "drivers" folder and installs them as needed during an installation. This drivers process is new to me so I apologize if the questions seem a little ignorant. EDIT: I see BrokenZer0 made a post on this as well http://www.wincert.net/forum/topic/12409-driverpacks-integration/?p=110458I will try and research further. Assuming you've mounted the image at least once. You just copy and paste the drivers into sources\\drivers folder. Edited October 28, 201410 yr by compstuff
October 28, 201410 yr WIM Manager > Mount Image > Unmount Image (Save). DVD\\Sources\\Drivers > Copy and paste drivers >> Done.The first step adds the RunOnce program for it to work.
