sorry i didn't mean that i mean im editing windows and i'll remove ie6 from windows xps sp3 and i'll integrate ie8 else but i want to integrate a new browser like avant and make it the main browser did you understand what i mean bro ?
Ok you cannot remove ie6 and then add ie8. IE8 is built on the frame of IE6 it won't work that way.
What you need to do is get a utility like regshot and "catch" the reg entries when you install and configure avant. Then just add those in in anyway you add reg files (there are a dozen or so ways for that...)
