Posted November 9, 201410 yr Howdy everyone,New to Win Toolkit, I have a Windows 7 Pro SP1 x64 original setup DVD and just want to integrate all the updates to it, nothing more, no anymore change, no even IE11.So I have copied the contents of DVD to C:\working\isoI have copied all 172 .msu offline updates I had to C:\working\updatesAnd after half hour, I faced error that 169 errors occured and 169 updates was NOT integrated!I am very newbie to this, can someone help me please?! -Log was big and I rar it, it's attached.ErrorLog.rar
November 9, 201410 yr On 11/9/2014 at 11:14 AM, hayedeh said: ......New to Win Toolkit, I have a Windows 7 Pro SP1 x64 original setup DVD and just want to integrate all the updates to it, nothing more, no anymore change, no even IE11........Are you shure you are using an image of Windows 7 SP1? Because your image-version is that one from Win7 RTM. From your log: Quote Image Version: 6.1.7600.16385Should be 6.1.7601.17514. Are you working as admin? Quote Access is denied. Regards, Thiersee
November 10, 201410 yr Author Thanks dude, please help me a little more: 1. What do you mean by image of Windows 7 SP1? I have downloaded .iso of Win7Pro SP1 x64 from Digital River and extracted the whole contents, so what should I do? 2. Win Toolkit is always run as Admin, so yes it's Admin, something else I am missing? I am also Admin of PC. Thanks.
November 10, 201410 yr On 11/10/2014 at 4:13 AM, hayedeh said: .....1. What do you mean by image of Windows 7 SP1? I have downloaded .iso of Win7Pro SP1 x64 from Digital River and extracted the whole contents, so what should I do?......Which image did you download (X17-xxxxx)?
November 10, 201410 yr Unlike x86, Win7 SP1 x64 image version in default is reported by dism as 6.1.7600.16385
November 10, 201410 yr On 11/10/2014 at 9:36 AM, abbodi1406 said: Unlike x86, Win7 SP1 x64 image version in default is reported by dism as 6.1.7600.16385Are you shure? WinToolkit: NTLite: Thiersee Edited November 10, 201410 yr by Thiersee
November 10, 201410 yr Author (X17-xxxxx) sorry I renamed the iso file and I don't know which image was that, but I'm sure it's the latest version, after installing it shows 6.1.7601...
November 10, 201410 yr On 11/10/2014 at 9:50 AM, Thiersee said: Are you shure? WinToolkit: NTLite: ThierseeWhen using x86 dism, the Win7 SP1 x64 version is reported as 6.1.7601.17514but when using x64 dism, the Win7 SP1 x64 is reported as 6.1.7600.16385the cause of this confusion is when servicing x64 image using x86 dism, Windows\SysWOW64\Dism\DismHost.exe from the image is used (and its version 6.1.7601.17514)but when servicing it using x64 dism, Windows\System32\Dism\DismHost.exe is used (and its version is 6.1.7600.16385) Edited November 10, 201410 yr by abbodi1406
November 10, 201410 yr On 11/10/2014 at 7:53 PM, abbodi1406 said: When using x86 dism, the Win7 SP1 x64 version is reported as 6.1.7601.17514but when using x64 dism, the Win7 SP1 x64 is reported as 6.1.7600.16385the cause of this confusion is when servicing x64 image using x86 dism, Windows\SysWOW64\Dism\DismHost.exe from the image is used (and its version 6.1.7601.17514)but when servicing it using x64 dism, Windows\System32\Dism\DismHost.exe is used (and its version is 6.1.7600.16385) May be.But using DISM (6.3.9600.16384) from Windows 8.1 (Windows Kit\8.1\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe), and WTK uses this version, seems to be the same.Just tested using DISM x86 & x64 and the result is the same, it shows in both cases 6.1.7601.17514 for my x64 Win7Pro ISO. WTK-Options: Thiersee
November 11, 201410 yr Does the actual dism report 6.1.7601.17514? for me i get 6.1.7600.16385 on x64 system:it seems something not solid, so 6.1.7600.16385 doesn't always means RTMsorry for hijacking your thread hayedeh
November 11, 201410 yr Author No problem at all, but please help me integrate my updates to my Windows setup DVD, I am newbie and don't understand you.
November 11, 201410 yr All the errors in you log indicates ACCESS DENIEDif you have Anti-virus, stop it, real time scanning may prevent the process and you may try this fix:http://support.microsoft.com/kb/968003 Edited November 11, 201410 yr by abbodi1406
November 11, 201410 yr Author No luck, same, so anyone can help me? In the meantime, I have installed Windows Automated Installation Kit, is this requied for Win Toolkit to work or I can uninstall it?
November 11, 201410 yr Author I have attached my project ini so you can check and give me any suggestions you might have?! Win 7 Pro.ini
November 11, 201410 yr No, it isn't. Try first to integrate ONLY updates, without removing components. Thiersee
November 11, 201410 yr Author I also tried integrating only updates without removing components.Same result, what's wrong?! Please help (
