Hello everybody.
First of all: Bad English Mode is On!!! it s not my common language so please be patent.
I m playin around with the toolkit and all the iso integration stuff for the first time.
Installing updater works pretty good but with the silent installers  i have my little problems.
i added 3 silent installers which  i tested on a machine, so i know the cmdlineargs work.
while installing windows process i dont the any errors or installations.
after rebooting etc the software isnt installed. so i think mit has not started. ?
so i looked into the iso to find out how you implement the installations.
I had found the install.ini file, but it is empty.
How do you install the apps?
the Folder with the installers are on the iso.
How and when is it getting started.
After First Reboot?
Do you copy the Files to C:\?
I always have to unplug my usb stick on first reboot, so it doesnt get into install  loop.
Is this the errro?
