MagicISO Maker v5.5 (Build 281) + MagicDisc v2.7.106 -- RePack
by niTe_RiDeR_Pro
MagicISO MakerMagicISO is a powerful CD/DVD image file creating/editing/extracting tool. It can open, create, edit and extract CD/DVD image files, and it can convert BIN to ISO formats and back. You can use it to make ISO files from DVD/CD-ROM or hard disks, with bootable information included. MagicISO can also convert any image file format including BIN to the standard ISO format. It can handle images created by CD burning software (Nero Burning ROM, Easy CD Create, and so on) or virtual DVD/CD-ROM driver software (Daemon-tools).
MagicDisc: MagicDisc Virtual CD/DVD-ROM is a utility designed for creating and managing virtual CD drives and CD/DVD discs. MagicDisc Virtual CD/DVD-ROM emulates audio, data, and game CDs and DVDs with ISO image, CD and DVD images. MagicDisc Virtual CD/DVD-ROM offers 200x speed and noiseless CD/DVD access without a physical drive. It supports creating up to 15 virtual drivers. You can run games, software, see movies (VCD, SVCD, DVD), and hear music directly from your hard disk without inserting and swapping CDs and DVDs.  It works like a real CD/DVD-ROM. It can compress ISO CUE MDS NRG CCD image; can encrypt ISO CUE MDS NRG CCD image; can make ISO image from CD/DVD; It can mount UDF only CD/DVD image and multi-session MDS/MDF and CCD/IMG image.
NOTE - You can select which programs to install in the setup wizard. This is the trial unregistered version of MagicISO. MagicDisc is a freeware.
Command Line Options:
Usage:      miso.maker.5.5_mdisc.2.7.106_repack-_-niTe_RiDeR.exe [switch]
                                                  All switches are optional.
Switches:
/SILENT: Passive installation, shows only installation progress. NO user input required. Installs ALL packages.
/VERYSILENT: Fully silent installation, shows no GUI at all. NO user input required. Installs ALL packages.
/NORESTART: Prevents setup from restarting after a successful installation.
/SUPPRESSMSGBOXES: Instructs setup to suppress(remove) message boxes. Only effective when used with /SILENT or /VERYSILENT switch.
/LOG: Caused setup to make a log file in the User's temporary directory (Mostly the temporary directory is at "%USERPROFILE%\AppData\Local\Temp").
/COMPONENTS="componentname": Tells setup which components to install. In this setup the component names are: magiciso (for installing MagicISO Maker) & magicdisc (for installing MagicDisc).
Examples:
  • Install MagicISO Maker & MagicDisc silently by showing only progress (passive mode) & without restarting automatically and create a log:
  • Install MagicISO Maker only, fully silently without restarting automatically:
miso.maker.5.5_mdisc.2.7.106_repack-_-niTe_RiDeR.exe /SILENT /NORESTART /SUPPRESSMSGBOXES /LOG
miso.maker.5.5_mdisc.2.7.106_repack-_-niTe_RiDeR.exe /VERYSILENT /NORESTART /SUPPRESSMSGBOXES /COMPONENTS="magiciso"
File Name: miso.maker.5.5_mdisc.2.7.106_repack-_-niTe_RiDeR.exe
File Size: 4.89 MB (51,33,035 bytes)
Architecture Supported: Both (x64 & x86)
MD5: B3BCEC337246BB452F8B59E4B1EC86A7
SHA1: 838A5BA53083B7544AEAE64952E706C2B7E15D9A
Enjoy! :thumbsup:
Edited by niTe_RiDeR_Pro
